2.0 T fault code
hades-
Well-Known Member
any ideas cam follower ok and changed fuel filter changed
[h=2]18725/P2293/008851 - Fuel Pressure Regulator Valve (N276): Mechanical Malfunction[/h][h=4]Possible Symptoms[/h]
  • Malfunction Indicator Light (MIL) ON
  • Power Loss
[h=4]Possible Causes[/h]
  • Fuel Pressure too Low
  • Intake Camshaft Failure
[h=4]Possible Solutions[/h]
  • Check Measuring Values for Fuel Pressure
  • Check for bent/squeezed Fuel Lines
  • Check Fuel Pressure System for Leaks
  • Check Fuel Filter & Filter in Fuel Pump
  • Check Fuel Quantity supplied by the Fuel Pump
[h=4]Special Notes[/h]
  • When found in 2.0l TFSI:
    • Rest of World (RoW) check TPI 2014143, the Intake Camshaft might have a worn out Fuel Pump Cam.
    • North American Region (NAR) check TSB 2015153 (01-09-03 > 15-10-01 > 15-10-02), the Intake Camshaft might have a worn out Fuel Pump Cam.
    • North American Region (NAR) check TSB 2018183 (20-08-01) and verify the High Fuel Pressure Sensor (G247) Part Number
Retrieved from "18725/P2293/008851 - Ross-Tech Wiki"
Category:
[h=5]Categories[/h]
[h=5]Meta[/h]
http://www.aapexshow.com/
right its had a new HPFP and follower
cam sensor fuel line that was a bit kinked (prob happend when hpfp was replaced
fuel filter
366
541
856
