Need help with vcds
Adamstubbins
Can anybody help with this scan I've fixed the brake pressure sensor just the control module thanks
Friday,01,February,2013,17:44:32:19586
VCDS Version: Release 11.11.5
Data version: 20121222
Chassis Type: 1K0
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 47 52 56 7D
VIN: WAUZZZ8P34A135604 Mileage: 167900km/104328miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 1010
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 1010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 1010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 1010
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: Malfunction 1010
52-Door Elect, Pass. -- Status: Malfunction 1010
56-Radio -- Status: Malfunction 1010
7D-Aux. Heat -- Status: Sporadic communication error 1000
Address 01: Engine Labels: 03G-906-016-BKD.lbl
Part No SW: 03G 906 016 AT HW: 028 101 145 3
Component: R4 2,0L EDC G200AG 5689
Revision: 12345678 Serial number: AUX7Z0D1FN90B3
Coding: 0000078
Shop #: WSC 00359 210 53633
VCID: 75EBCCF91C8DB4B002A
No fault code found.
Readiness: 0 0 1 1 1
Address 02: Auto Trans Labels: 02E-300-0xx.lbl
Part No SW: 02E 300 041 C HW: 02E 927 770 AD
Component: GSG DSG 0623
Revision: 04202624 Serial number: 00001002250639
Coding: 0000020
Shop #: WSC 06314 210 01865
VCID: 122197650D230388878
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0103
Coding: 0023174
Shop #: WSC 06435 000 00000
VCID: 3A711FC575131BC82F8
1 Fault Found:
01435 - Brake Pressure Sensor 1 (G201)
012 - Electrical Fault in Circuit
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 D HW: 8P0 820 043 D
Component: KlimavollautomatH12 0150
Revision: 031759 Serial number: 8P0820043D
Shop #: WSC 00000 000 00000
VCID: 2D5B2499B45DBC70BAA
Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 D HW: 8P0 907 279 D*
Component: Bordnetz-SG 1.0 H28 0601
Revision: 00028000 Serial number: 00000000483290
Coding: A4885F00A2141000000000000000000000
VCID: 3E7913D5693B37E8130
Subsystem 1 - Part No: 8P2 955 119 C Labels: 1TX-955-119.CLB
Component: Wischer WWS Audi350 0180
Coding: 16711696
Shop #: WSC 00000
Address 15: Airbags Labels: 8P0-959-655-84.lbl
Part No SW: 8P0 959 655 D HW: 8P0 959 655 D
Component: Airbag 8.4ED H00 0140
Coding: 0011602
VCID: 438F622102D95A007CE
Address 16: Steering wheel Labels: 8P0-953-549.lbl
Part No SW: 8P0 953 549 HW: 8P0 953 549
Component: Lenksäulenmodul H11 0020
Coding: 0011122
VCID: FBFF5AC1BAA962C0F4E
Part No: XXXXXXXXXXX
Component: Lenkradmodul H02 0030
Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
Part No SW: 8P0 920 980 H HW: 8P0 920 980 H
Component: KOMBIINSTR. VDO H25 0140
Revision: D09 Serial number: 2241DD09003954
Coding: 0002403
Shop #: WSC 00581 067 57207
VCID: 3C7D19DD7F2725F83D4
1 Fault Found:
00003 - Control Module
014 - Defective
Freeze Frame:
Fault Status: 00000011
Fault Priority: 1
Fault Frequency: 1
Mileage: 81205 km
Time Indication: 0
Date: 2008.08.22
Time: 09:05:53
Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 D HW: 1K0 907 951
Component: Gateway H08 0100
Revision: 08 Serial number: 2500104113003A
Coding: 3F0F0B42070101
VCID: 2855D58D9BBF995849C
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D09 Serial number: AUX7Z0D1FN90B3
Shop #: WSC 00763 210 80270
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN1.lbl
Part No: 8P0 959 801 A
Component: Tuersteuerger. H10 0010
Coding: 0000120
VCID: 397300C9701510D0262
1 Fault Found:
00932 - Electric Window Motor; Drivers Side (V147)
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K2 909 144 E
Component: EPS_ZFLS Kl.10 1202
VCID: 2E592395B95BC768830
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433
Component: KSG H02 0040
Coding: 008800186D288505485AC63000
VCID: F9F340C9B09550D0E62
Part No: 1K0 951 605 A
Component: LIN BACKUP HORN H01 1201
Part No: 1K0 907 719
Component: Neigungssensor 003 0003
Part No: 8P0 951 177
Component: Innenraumueberw.H03 0010
1 Fault Found:
01299 - Diagnostic Interface for Data Bus (J533)
013 - Check DTC Memory
Address 47: Sound System Labels: 8Px-035-382.lbl
Part No SW: 8P3 035 382 HW: 8P3 035 382
Component: AB2 SUBWOOFERBOXH23 0100
Revision: 00001 Serial number: 10000001075899
VCID: F0E57DEDE3EF119851C
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN1.lbl
Part No: 8P0 959 802 A
Coding: 0000120
Address 56: Radio Labels: 8P0-035-1xx-56.lbl
Part No SW: 8P0 035 186 HW: 8P0 035 186
Component: concert II EU H53 0060
Revision: 07S Serial number: AUZ2Z3D1846317
Coding: 0001001
VCID: EFE77E91FED10E60486
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 D HW: 1K0 963 235 D
Component: PTC-Element 0404
Revision: 00700000 Serial number:
VCID: 2C5D299D8F47B578AD4
End ---------------------------------------------------------------------
Never seen so many "Status: Malfunction 0010" from one scan...
The good news is his Steering Angle Sensor & Immobiliser are Okay! :jester:
Seriously though, you probably need to clear all faults and rescan so others can see what's what.
go into Module 17 and clear it from there, scan again.
Infact, do all your modules one by one, select Fault Codes - 02, then Clear codes - 05 and that should clear the first bit too.
Window just needs the one touch system setting, by using the window switch to drop window fully whilst holding button & an additional 10 seconds when fully open & release, then close using the same process.
The cluster saying defective doesnt look good, as above stated, module 17, got into fault codes, click clear codes, cycle ignition, start car & test again & post results.
861
615
fad
987
