VCDS coding xenon to audi a3 2004
imy2k
Member
Luton
Hi all, I need to code in my single Xenons i bought from ebay to my audi a3 2004 they are all fitted and sorted and work just need to code them in and make the dash warning light go away. I understand i have to go into to 09, CE module, and check on byte 21. Firstly the bytes did not go that far thus i entered 00 untill it go to byte 21 and selected the option on xenons from the drop down menu and copied the long code and when i tried to enter this back on to it did not allow me too save the code. Are the options different on an 2004 A3? Thanks in advance
I will try get one up asap but does not help as i'm using my employers cable at there garage.
Subscribed, i will be doing this shortly to my A3 which is also a 2004 but mine already has xenons so hoping the CE supports it!.
Turns out i don't have byte 21 , How can i tackle this ?
As advised before, provide a log so we can see what modules are installed.
Slight thread hijack but NHN could you please advise on mine mate for bi-xenon ? : part of the scan.
Shop #: WSC 00000 000 00000
VCID: 2F676218C78D
No fault code found.
Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 A HW: 8P0 907 279 A*
Component: Bordnetz-SG 1.0 H30 0501
Revision: 00030000 Serial number: 00000000403829
Coding: 038A4F00A2141000000000000000000000
VCID: 3B7F464803F5
Part No: 8P2 955 119 A
Component: Wischer WWS Audi350 0170
Coding: 16711696
Shop #: WSC 00000
1 Fault Found:
00924 - Relay for Headlamp Cleaning System (J39)
009 - Open or Short to Ground
Address 15: Airbags Labels: 8P0-959-655-84.lbl
Part No SW: 8P0 959 655 D HW: 8P0 959 655 D
Component: Airbag 8.4ED H00 0140
Coding: 0011602
3K
NHN
643
