mmi upgrade
vw754
vorsprung Durch Technik
U.K
is it worth getting the cd pack to upgrade the mmi in a 2006 q7 ? ive heard it can even eliminate battery drain,and other bug fixes?
mine got the 4 772 i think the latest is 5570 ? any pro's, cons? component protection be affected?
Never heard of it fixing battery drain, i think your clutching at straws there, it removes the battery monitoring from the MMI and you have to manually put it back (if you had it in the first place)
It has some bug fixes for the bluetooth and other bits, so it is worth doing to bring things up to 5570. But be aware if it goes wrong you can feck up a module and that can be costly.
ok,thanks,can it go wrong? what happens if i dont put the battery monitoring back in?
It's rare to go wrong, nothing happens if you don't put it back, you just get frustrated as your missing a function from the MMI.
As you have such a high version already your not likely to lose functions that are there, it happens when you upgrade from lower rev software such as 2120.
ok,nice one,aslong as i do what instructions say,i should be ok then, my version is SW:42.2.0 0709 42.20 THEN? I THINK.
IF ANY,or il just start with cd 1,2 and 3.....ive read somewhere to use cd 2 twice?,im sure it will come with instructions if i buy from audi.
What instructions?
if i get the 2013 sat nav cd from any audi sat nav, will it work in my q7?.........or just update mmi?
No it doesn't come with any, the disks are for installation by technicians so no instructions are provided.
ok,is it quite simple then,just insert each disc one by one in the in-dash 6 disc changer?
ordered the 3 mmi discs from audi,how do i put the battery monitoring back ?
33K
22
14K
957
