Is that a b7 the 2.0?
I've just picked up a bv43, gunna fit it when I have found a suitable front mount. It is a direct swap for the old one, bolt on bolt off. Should work well with a decat.
What FMIC are people running please?
No need for a fmic, stock intercooler is adequate unless you live in Africa ! Watch the gearbox with the bv43...I've just picked up a bv43, gunna fit it when I have found a suitable front mount. It is a direct swap for the old one, bolt on bolt off. Should work well with a decat.
I think thats only on the 2.5, the 1.9 only has the single Intercooler if i remember rightly, the 2.5 has Twin Intercoolers (One either side). Which i have also been told is 250-300bhp capable but i really fail to see how even non forward facing wing mounted plastic ended twin intercoolers can can be anywhere near as efficient as a fully aluminium single fmic mounted in the bumper behind a votex kit.
Somebody may put me right, but in my opinion you would shorten the length of tube the air has to travel, hence fill the pipes faster and less lag. but i could be wrong
Mine just munched the syncromesh in 3rd gear and now the box is locked in 1st ! The single mass flywheel and heavy duty clutch did not help and probably leaded to a premature death ! Just bought a full 1.9Tdi quattro 2004 to use for parts for that conversion, it would have been too much to buy the exhaust, downpipe and rear subframe/box/diff and tank. This way i know it would bolt on !Do BV43's kill gearboxes? How would it handle on a stock 5 speed? Guessing single mass flywheel and VR6 clutch are necessary.
I kinda doubt it my friend, me other c5 v6 tdi quattro is capable to return 48Mpg average if driven steadily !You'll have a monster when that's finished, two hundred bhp easy and better mpg than any car with that power.
