a3 2.0 tdi 140 (bkd)
scoty
hi having problems with ma a3 tdi 3 weeks ago the car cut out and wouldn't start the next day it started for 10 min then cut out again checked for fault codes but none came up replaced fuel filter the next day and car started and had been ok till Thursday.when it started to run rough then cut out and would not start checked for codes and p0202,p0203 injector 2,3 open circuit.so cleared codes but still wouldn't start checked injector resistance all ok.put back together and tried to start and car started for 10 min with a few misfires and then it cut out.and wont start again with the same two fault codes back.any info would be great cheers scoty
Break in the wire somewhere on the injectors, could be a bit intermittent though.
