Another 'Will these fit' thread
LaytonA3
First off, I'm relatively new to this forum so hi all!
I was looking at buying some Rs6 alloys (reps)
They are 18 x 8.5J (ET38)
Will they fit?
I think You will need some 2 mm spacers bud , not 100 % tho
I i
Hi Buddy and welcome to ASN! If you were to add 2mm spacers, that would effectively change the offset to ET36, which would make the wheels stick out even more in the arches. I ran 8x18" ET44 BBS CK's with 225/18/40 tyres and even these rubbed slightly, so my advice would be to look at other options as those wheels you're thinking of are another 1/2" wider so would deffo rub. For 18x8" wheels, the lowest offset without any rubbing would be ET45. You could get away with a slightly lower ET if you run lower profile tyres (ie 215's), but I would say that an 8.5" rim with ET38 is a no no for the A3/S3, unless you want to do some arch work, etc. Hope this helps. Paula :wub: xx
Nice one, thanks for clearing that up. Much appreciated and saved me alot of hassle :)
554
574
853
