vag com fault codes. help please?
Steven.c
Auto-Motive Restored Deatail
Shropshire - West mids
Hi, i have a audi a3 1.8t AUM fwd. lately the car has been acting strange so i scanned it and it came back with these faults.
Address 01 -------------------------------------------------------
Controller: 06A 906 032 FC
Component: 1.8L R4/5VT G 0002
Coding: 11500
Shop #: WSC 02629
WAUZZZ8LZ1A041577 AUZ7Z0Y1605717
2 Faults Found:
16486 - Mass Air Flow Sensor (G70): Signal too Low
P0102 - 35-10 - - - Intermittent
16804 - Catalyst System: Bank 1: Efficiency Below Threshold
P0420 - 35-00 - -
Readiness: 0000 0000
Address 03 -------------------------------------------------------
Controller: 1C0 907 379 E
Component: ESP FRONT MK60 0103
Coding: 0019970
Shop #: WSC 06435
1 Fault Found:
01164 - ESP Operation
008 - Implausible Signal - Intermittent
Address 17 -------------------------------------------------------
Controller: 8L0 920 980 E
Component: AB-KOMBIINSTR. VDO D12
Coding: 00444
Shop #: WSC 00088
1 Fault Found:
00562 - Sensor for Oil Level/Temperature (G266)
30-00 - Open or Short to B+
Unsure on the MAF one as i have only just replaced it the day before with a genuine bosche one?
The esp one is the one that worrys me the most as it flashs up on the dash and its like the brakes go strange and abs kicks in?
any help would be much appreciated
many thanks
steve
Did you try clearing them first as they are all intermittent and the air mass one could be due to changing it.
I have the same oil light, sometimes it works sometimes it doesnt, likely the senser in the sump, £90ish to replace from stealer iirc.
3K
922
3K
5K
