Mpg on clocks
vwgtiking
I notice I have miles to empty but does the clocks somehow display the mpg???
Also I have vcds what tweaks can I do?
Depends if you have DIS or not. Look on the and of the right hand stalk and there will be a switch that scrolls the display.
No scroll!?! Can I get mpg?
Not without upgrading your hardware (i.e. a new stalk with the rocker switch, and likely a new steering column control module). Can be done DIY for around a hundred quid, but if you don't have the tools and coding software it's probably cheaper to pay someone to do it...
Is there a noob guide with full details? Can I turn mpg on in place of mte via vcds without stalk?
The following is a guide (not mine) for installing cruise:
http://dl.dropbox.com/u/103952776/A4%20Cruise.pdf
The method is basically the same for DIS except you switch the wiper stalk for the rocker-switch one instead of adding in the cruise stalk (or do both which is what I did)...
No. But you will need to code in the DIS after installing the stalk - I have a guide for that linked from my sig...
