alloy wheels WTF
brownie 25
hi all i picked up a set of rs6 wheels that are marked 5x112 but wont fit.i have rs4's on now which are also marked 5x112 and they do fit. /??????????????????????????????
Hello,yes they are reps ,its the bolt holes that don't line up but there clearly marked 5x112 i'm not that bothered tho i only bought them because the were cheap and when i say cheap i mean i got the set with 4 tyres witch are 90% for the price of one tyre so i'm now on the look out for a nice set of 19S
ah way to far away,
i ment a picture of the holes with a ruler or messuring tape if there reps they could have been stamped up wrong, and might be 5 x 108 rather then 5 x 112
no not on a 5 bolt
you draw an imaginary line round the bolts as a circle. or you can actually do it if it makes it easier. and messure from one bolt directly across the circle to the line as below
Pcd explained 5 stud 1
make sure you do this as acuratly as possible as 108 and 112 pcd is very close im unsure why vw/audi even bothered with the slightly diffrent sizes
Are there just 5 bolt holes or more? I had a set of reps which were multifit 5X110 or 5X112
don't know if you can see this...ahh posted before checking back here so i have measured them wrong,either way they wont fit so at least i have a cheap set of tyres.
checked again going by the diagram and the are 108,
665
586
