Coil pack wiring loom
Stuart35205
Telford
Is it possible to get the loom desperately as mine is realy tatty with bare wires showing etc cheers
Yes... been discussed before... several members (including myself) have done this... there is even a write up in Westy's build thread...
Have a search :)
Yes mate,
Pretty sure Awesome GTI sell them with and without oil sensor as I was looking to replace mine when I did my TFSI coilpack conversion.
Not the easiest to replace the whole of it though as it requires routing it the ECU and re-soldering from what I've seen.
I have 1 out of the 4 plugs in perfect condition...the rest have seen better days! lol
Will you be carrying out the work yourself? If so then there is full explanation in the guides under Maintenance manuals I believe - posted by Welly
Find westy's build thread... first page, it even has an index...
Brilliant lad will have a butchers , I may try it myself depends on hoe it looks!
the index is spot on and the write up is very good I think I'm going to order one if there only £30 and do it wire by wire aswell , cheers for the advice all
809
762
19
