Hi folks im have a nightmare with an audi TT 180 1999 with full service history 94k i just bought...... problem is the car is overheating....it runs between 94c while driving and 107c when in slow traffic and on a hill according to the 49c aircon test....... the dash guage is at 120+ in the red.....the 51c test show the engine at 90c im not getting any boil over no hoses blown off of steaming expansion bottle but the engine bay is like an oven when opened
i have changed the water pump,
thermostat,thermostat housing,
flushed the cooling system,proper mix of g12,
a new coolant temp sensor.....
also full service new oil,filter,timing belt,drive belt,tensioner,damper,air filter,
oil levels are just over 3/4 on the dipstick
im at my wits end you can really feel the heat in the engine bay it's actually starting to affect belts and stuff it's so hot......
the fans were not kicking in either aircon or main fan so i wired them to a switch and relay to be on full time still makes no difference to the temp.....
i have ordered a new fan control relay for the rad fans but still cannot figure out why its running so damm hot with the fans on all the time......you can feel the heat blasting out the front of the radiator too
the new water pump seems to be circulating ok in the expansion bottle....both rad hoses are hot...a little firm.... so i thought head gasket.........but hot air is fine in the cabin...no white smoke.....no coolant loss or coolant in the oil or oil in the coolant....no power loss.......no mayonaise under the cap...........im freaked out dont know what else to do......pls guys any help im really up a creek here any experienced members or vag mehanics i really need your help......
