Trying to investigate a misfire I'm getting when the engine is under load. The misfire is only happens above 2500rpm but then it's quite bad. Pottering round town is fine. Having read the forums alot of people are suggesting coil packs which initially seems logical. Question is, would a failing coli pack cause a constant fault rather than just one over 2500rpm. Initially I got the emission warning light flashing which dissappeared if I eased off but it's now on constantly regardless of speed. Unfortunately I don't have VCDS. I was going to get a new pack and swap out the old ones till I found the culprit but wanted some reassurance I was looking in the right place? Cheers
