Centre Air Vent Not Blowing Air Out!
wyliss
North West
Blimey. After fixing my starting problem another has arisen.
Basically as title really.
Air con is fine and blower motor works no problem!
Any ideas?
Could be a motor has failed, ideally with vcds, do a basic setting 001 in module 08 & see if this fixes the issue, if not then I suspect motor needs replacing.
Take the glove box out and you will see the motors, turn the vents/window vents on and see if the motor moves. That should at least tell you if the motors working. Im not sure which one it is but play with the buttons and see if all the motors move, if one doesnt then that should be the one
689
458
