VAG-COM Logs
rraghvani
Whoever does not try, does not learn.
Surrey
Website
audi-sport.net
Hello,
Finally got round to do some vag com logging (from old post). I've attached .csv files that are zipped which consists of blocks 002, 020, 115 and 003, 020, 118.
Would it be possible to get some feedback on these please?
Thanks.
would it be possible to post the data in [ t ag ] form...
I am probably not alone in not wanting to click on anyones .zip files.. (no offence)
Reactions: s3dave and Vex182
How's this,
Blocks 002-020-115
Tuesday
12
November
2013
21:39:12:46904
VCDS Version: Release 12.12.0
Data version: 20130910
8N0 906 018 BH
1.8L R4/5VT G 0001
Group A:
'002
Group B:
'020
Group C:
'115
Engine Speed
Engine Load
Injection Timing
Mass Air Flow
Timing Retardation
Timing Retardation
Timing Retardation
Timing Retardation
Engine Speed
Engine Load
Boost Pressure
Boost Pressure
TIME
(G28)
Sensor (G70)
TIME
Cylinder 1
Cylinder 2
Cylinder 3
Cylinder 4
TIME
(G28)
(specified)
(actual)
Gear
STAMP
/min
ms
g/s
STAMP
°KW
°KW
°KW
°KW
STAMP
/min
mbar
mbar
3rd
0.83
2200
32.3
3.06
14.08
0.23
2200
31.6
990
1010
1.74
2360
95.5
8.5
47.67
1.14
2280
85
1670
1060
2.64
2720
136.1
13.94
77.75
2.04
2600
121.8
2210
1440
3.55
3200
181.2
20.4
106.56
2.95
1.5
4.5
3.25
3040
180.5
2380
2120
4.46
3760
176.7
19.38
125.17
3.85
4.15
3560
178.9
2370
2150
5.36
4240
170.7
18.02
136.97
4.76
4.5
1.5
5.06
4080
172.9
2350
2050
6.27
4720
163.9
17
146.11
5.66
4.5
5.3
4.5
1.5
5.96
4560
166.2
2320
1950
7.17
5200
160.9
17
160.94
6.57
4.5
4.5
3.8
5040
160.2
2330
1940
8.08
5640
162.4
17.34
176.39
7.47
5.3
4.5
3.8
5480
163.2
2360
1930
8.98
6040
165.4
17.68
187.14
8.38
5.3
4.5
4.5
3.8
8.68
5880
165.4
2360
1930
4th
0.59
2080
37.6
3.4
15.19
2080
30.8
990
1010
1.51
2160
85.7
8.16
40.03
0.9
2120
47.4
1260
1000
2.4
2360
117.3
11.22
56.97
1.81
2280
106
2030
1270
3.32
2600
151.1
15.3
82.36
2.72
2520
138.3
2190
1660
4.22
2920
177.4
19.72
97.64
3.62
1.5
3.92
2800
178.9
2340
2160
5.13
3280
177.4
20.06
109.64
4.53
1.5
3.8
2.3
1.5
4.83
3160
181.2
2390
2210
6.03
3600
176.7
19.38
121.36
5.43
3.8
3480
178.2
2370
2140
6.94
3920
174.4
18.36
132.28
6.34
5.3
3840
176.7
2350
2100
7.84
4240
168.4
17.68
136.97
7.24
5.3
4120
172.2
2330
2050
8.75
4520
165.4
17.34
143.36
8.15
4.5
5.3
5.3
4.5
8.45
4440
167.7
2300
2010
9.65
4800
160.2
16.66
147.28
9.05
4.5
4.5
4.5
4.5
9.35
4720
158.6
2270
1940
10.56
5080
159.4
17
154.75
9.96
3.8
4.5
3.8
10.26
4960
161.7
2290
1880
11.46
5320
160.9
17
163.94
10.86
4.5
3.8
3.8
11.16
5240
160.9
2270
1910
12.37
5560
159.4
17
174.06
11.77
5.3
5480
160.9
2270
1940
13.28
5800
162.4
17.34
176.97
12.67
4.5
3.8
3.8
12.97
5720
160.9
2280
1980
14.18
6040
157.1
16.66
182.89
13.58
5.3
3.8
5.3
3.8
13.88
5960
161.7
2270
1860
15.08
6240
156.4
16.32
187.14
14.48
5.3
6160
159.4
2270
1890
15.99
6320
156.4
17.68
194.25
15.39
4.5
3.8
4.5
3.8
15.69
6400
156.4
2270
1910
Blocks 003-020-118
Tuesday
12
November
2013
21:58:07:46904
8N0 906 018 BH
1.8L R4/5VT G 0001
Group A:
'003
Group B:
'020
Group C:
'118
Engine Speed
Mass Air Flow
Throttle Valve Angle
Ignition
Timing Retardation
Timing Retardation
Timing Retardation
Timing Retardation
Engine Speed
Intake Air
Boost Pressure
Boost Pressure
TIME
(G28)
Sensor (G70)
Timing Angle
TIME
Cylinder 1
Cylinder 2
Cylinder 3
Cylinder 4
TIME
(G28)
Temperature (G42)
Control (N75)
(actual)
Gear
STAMP
/min
g/s
°BTDC
STAMP
°KW
°KW
°KW
°KW
STAMP
/min
°C
mbar
3rd
0.6
2000
5.69
3.9
-4.5
000000.31
2040
21
01040
1.52
2080
38.17
95.7
20.3
0.91
00001.21
2040
21
100
1020
2.43
2400
59.39
98.4
00002.12
2280
17
100
1280
3.33
2840
95.28
100
9
2.73
00003.03
2680
14
100
1710
4.23
3400
114.64
100
13.5
3.63
4.5
3200
12
81.6
2240
5.14
3960
136.42
100
9
4.54
4.5
4.5
4.5
4.5
4.84
3760
10
79.6
2090
6.05
4480
146.53
100
17.3
5.44
4.5
4.5
4.5
4.5
5.74
4320
10
78
2050
6.95
4960
155.31
100
19.5
6.34
4.5
4.5
3.8
3.8
6.65
4800
76.1
1950
7.86
5440
175
100
16.5
7.25
3.8
3.8
3.8
5.3
7.55
5280
12
80
1920
8.76
5880
188.36
100
16.5
8.16
4.5
4.5
8.46
5760
14
80.8
2070
9.68
6280
195.53
100
19.5
9.06
3.8
4.5
9.36
6160
15
80.4
1950
10.58
6560
88.44
21.2
-5.3
9.97
3.8
3.8
2.3
3.8
10.28
6560
17
76.9
2040
4th
62.15
2280
41.42
99.2
23.3
61.56
000061.86
2320
63.07
2480
64.14
99.6
18.8
62.47
000062.77
2400
17
100
1320
63.97
2720
91.94
100
14.3
63.37
000063.67
2640
14
100
1790
64.88
3040
108.67
100
8.3
64.28
64.58
2960
12
85.5
2180
65.78
3360
115.39
100
8.3
65.18
1.5
65.48
3280
12
80
2180
66.69
3680
125.14
100
13.5
66.09
4.5
1.5
66.39
3600
12
78.8
2130
67.59
4000
136.53
100
18.8
66.99
4.5
4.5
67.29
3920
12
78.4
2090
68.5
4320
139.86
100
16.5
67.9
2.3
5.3
3.8
4.5
68.2
4200
13
77.3
2050
69.4
4560
143.89
100
18.8
68.8
3.8
5.3
3.8
4.5
69.1
4480
14
76.5
2000
70.31
4840
150.97
100
19.5
69.71
3.8
5.3
3.8
5.3
70.01
4760
15
76.1
1950
71.21
5080
156.28
99.6
20.3
70.61
5.3
4.5
70.91
5000
76.1
1930
72.13
5320
166.72
100
17.3
71.52
3.8
2.3
5.3
71.82
5240
1960
73.02
5560
174.06
100
20.3
72.42
3.8
72.72
5480
1950
73.93
5760
181.11
100
5.3
73.63
5680
20
79.6
1950
74.83
5960
187.44
99.6
17.3
74.23
4.5
3.8
74.53
5880
21
80.4
1990
75.74
6160
189.28
100
4.5
5.3
3.8
3.8
75.44
6080
22
83.9
1940
76.65
6320
192.08
100
4.5
4.5
3.8
6240
24
80
2000
1.3bar request and only 1-1.1bar actual but N75 duty cycle is'nt maxing out....
Odd. Load max % does'nt get that high...
sustained timing pull. What fuels in it?
What maps on it, and what do you find wrong with the car etc? (edit, revo in your siggy?)
I use 98 ron fuel, and its Revo stage 1.
I'm trying to figure out why my car doesn't pull like it used to.
Few months ago, I overtook a learner drive, down shifted to 2nd gear and accelerated. The car pulled very hard which I was not expecting. Since then, for about a month, it was accelerating quickly even at normal driving, even before 2.5k revs. It's a bit difficult to explain. Now it seems like its reverted back, not as fast.
do you have and SPS to check/adjust its settings?
what looks odd to me is the requested boost is'nt being met but the N75% does'nt look to be trying to max out to achieve it either..
weird
If SPS is Serial Port Switch, then I don't have that. What should the requested boost be, and what percent should the N75 max out at?
Also, how is Timing Retardation for the four cylinders calculated, considering only one cam shaft near inlet manifold varies the advance/****** angle via the timing chain tensioner?
- my car is weird, it decides where and when to apply power!
Its ignition timing not cam timing...
Timing retardation is calculated based on several factors... knock sensors, air temp, AFR, EGT's etc...
The advance you have logged is ignition advance, and timing correction from knock sensor intervention
VVT is something else.. block 092 etc
Your SPS settings on your revo determin what its going to ask for. Your logs on 115 show the request... the 118 shows actual ands N75% duty cycle... Normally, if turbo is physically incapable of achieving the requested boost, the N75% on block 118 would go to its max 95-100%..... Yours does not, whilst Still Not achieving requested boost. Thats what looks odd to me.
Do you think that the N75 is worn out, and may be on its way out?
I have noticed a slight crack on one of the vacuum hoses (the one that says 'Split here' near 06A-133-789 in http://www.audi-sport.net/vb/a3-s3-forum-8l-chassis/171914-vacume-brake-booster.html post). Also, the solenoid that’s on the cam chain tension, the connecting bit seems to fill with oil, and plus it can be rotated around. Which doesn’t seem correct to me! Don’t know if any of these could contribute to what you’re seeing in the output data.
FYI, I done the N249 bypass, and have Forge DV007 (blue spring) which is constantly serviced.
I've been doing some data logging again, after removing the lower vacuum pipes beneath the inlet manifold. I've compared my values with some of the forum users that have an Audi S3 2002 BAM Revo 1, and my values look pretty poor. The torque from standstill acceleration seems poor, boost seems pathetic - would be nice if someone can correct me on this and provide possible solutions as to where my power loss is occurring.
I've logged 002, 003, 020, 115 and 118, that's available in the attached text file. Download and open it in Notepad or similar, to check the contents & ensure it's not a dodgy file. Rename from .txt to .csv and open in Excel for better formatting.
  • LOG-01-02D-034-20F-115C-1184.txt
208 bhp ish, try loggoing 2000rpm third gear and floor it to the limiter you will get past 70mph so private road
WHY would you take the vacume pipe of the manifold?
Yes, the middle pipe from the inlet manifold has been blocked off; the side connects directly to the brake servo; two small pipes connect to recirculation valve and fuel pressure regulator. Note, before I did this modification, I've been suffering from lack of boost and torque for the last few years.
Not sure if anyone watches Wheeler Dealers, but they had a Saab 93 Turbo. They had used a TEXA OBD Log device to analyses and diagnose a boost issue at ~70mph. Eventually it turned out to be a damaged turbo, however they didn't actually say what normality they were looking for from the logs they got. I thought, if I can provide data logs, someone can analyse them and suggest possibilities to the cause of my issue.
