What have you done today?
F sake what a bunch of misfits. Simple to know how to Jack a car up. They paying to fix It?
They would be if I could narrow it down to which tyre fitter it was!! Both sides of the car have been jacked up using the floor and it’s destroyed the rubber grommets letting water in.
Looks like it’s been going for a long time so pin pointing who did it is impossible.
Worth checking though, if I’d have caught it earlier it would have been a relatively easy fix....now it needs to go to the local friendly welder.
... i did finish rear bumper with paint ...
... then I put a completely new complete exhaust from the turbine to the end ...
... and thats how it looks now and it will look to the end ...
I am very pleased with the final result.
Reactions: DCH, Maz, ToughlilT and 5 others
That has to be the best duplex exhaust set up on the S3 I’ve ever seen, good work bud! Look really good
Reactions: samurai
Nice work, I had a been thinking along the same lines but seen a rs4 rear diffuser on the s3 just need to pick up a spare rear bumper to mock it up
Reactions: samurai and S3AMJ
874B1344 80D4 4D90 8CA3 0DD841BF9A2A
Had a busy weekend all based around bringing the S3 into the 21st century. Fitted a MFSW, genuine Audi hands free Bluetooth, Dension Pro BT for music streaming, DAB radio module, new all in one DAB/FM/AM roof aerial, SDS (only for the handsfree so far as haven’t done the update on the RNSE) and reverse camera. All worked first turn of the key which I was amazed by :tearsofjoy:
Reactions: Maz, <tuffty/>, hydro s3 and 1 other person
Nice work. Are all the controls fully functional?
Yeah, all but the NAV button which I knew wouldn't do anything. Everything else is fully functioning even down to the buttons illuminating with the lights on.
Reactions: Rainbird
Great stuff. I've not entertained doing a similar swap myself, but remember reading older threads (and on the Golf forums) where it seemed a PITA to get the controls working. If it's doable, and hopefully not toooooo much of a ballache, then that's good news
It wasn't hard to do to be honest, @syncro did all the hard work and passed all the information on to me. I could never have worked it all out without him but once he explained what was involved it was pretty straight forward. I owe him a couple of beers :beercheers:. Re-wiring the airbag was a bit daunting and I wouldn't recommend doing it unless you're confident with that sort of thing (or using a different steering wheel/airbag combo with the same airbag connection as the original S3 one).
View attachment 165141 Had a busy weekend all based around bringing the S3 into the 21st century. Fitted a MFSW, genuine Audi hands free Bluetooth, Dension Pro BT for music streaming, DAB radio module, new all in one DAB/FM/AM roof aerial, SDS (only for the handsfree so far as haven’t done the update on the RNSE) and reverse camera. All worked first turn of the key which I was amazed by :tearsofjoy:
Any chance of a right up I’ve had this wheel fitted for ages and not got round to getting the controls working or the Bluetooth only thing working is airbag n horn
@Tj 0785 Not really much I can write as a guide for the Bluetooth, just wired it in (Mic In, Audio Out, Live, Earth, Can Hi, Can Lo & K Line), coded it in with VCDS and it all worked. What's your issue with it?
If you've got the airbag and horn working on your wheel you're halfway there. If @syncro doesn't mind me sharing some of his information I can do a write up for you of getting the MFSW controls working? It involves a bit of hunting for parts but I can supply you all the part numbers you need.
If you can would be good, He did email me about it months ago but I cannot find them with a rough sketch and odd part number
Leave it with me and I'll knock a guide up for you, might take me a few weeks because I haven't got much free time at the moment but I'll get your email address when I've done it and send it over.
Cheers do you know of the top of your head the part number for the Bluetooth mines not working and I know only certain ones are compatible
[QUOTE="warren9022,If @syncro doesn't mind me sharing some of his information I can do a write up for you of getting the MFSW controls working? It involves a bit of hunting for parts but I can supply you all the part numbers you need.[/QUOTE]
Yes that’s ok with me if you want to use any of that info or pictures to do a how-to/write up
Reactions: Stuart B, hydro s3, Tj 0785 and 2 others
So I did a thing today. NEVER EVER AGAIN
fair play, all in one piece.... I think most cut and hack the downpipe at the flex to get it out. My next purchase is a pipewerx downpipe, I don’t think I’ll be fitting it myself though.
Today I mostly took some pictures...
20180913 wm96dpi IMG 5343 Edit
20180913 wm96dpi IMG 5302
20180913 wm96dpi IMG 5336
20180912 96dpi IMG 5003 Edit
Reactions: Tomsy, Maz, hydro s3 and 3 others
Went to a audi meet up at Belfast audi that I was invited to by Sandra. Big thanks to Sandra as it was a good morning and lovely breakfast.
Took a lot of pictures but it won't let me upload them as it says there to big. We also got to see the new A6 that is not reviled until Wednesday so we where asked if we took pictures of it not to upload those until after that or they would get in to trouble.
I'm looking forward to the next one.20180915 094210
I'm looking forward to the next one.View attachment 165540
I just email pictures to myself or if on phone screenshot them so they are small enough
You
Must be a sucker for punishment, what power this one at? Any plans for it
Not really had a chance to have a good look but up till now I've discovered it's got
3"downpipe
sports cat
full non res milltek
fmic (need to see what kind, looks like a Forge as it's not massive)
AGU largeport head
horrible k&n filter
worst dv in the world (splitter r)
fuel pump sounds nice and starts first time so hoping that's been done
So up till now my main plan it to get a decent cone filter/heatshield and change the DV
Trying to find the owner who carried out the work, I'm not sure if the rods have been done, looking at the rest the work, I'm hoping they have
It needs a good stage 2 map, current map doesn't seem to be matching up with all the hardware imo, on a recent dyno run it made approx 250, not bad but could be better
@Tj 0785 What's your email address mate? Nearly finished this guide for fitting/wiring in the MFSW.
Post it up in a thread Warren? Then we could all refer to it for those of us who want to do the modification. It could go into the stickies as well then
After seeing photos of that lovely Ming Blue S3 under the bonnet it's time to up my game.......................
Hey Jackson, how much were the headlight rubbers? I’ve only recently noticed but I think mine have been cut down at some point in there lifetime. Any chance of being cheeky and asking for the product number as well mucho gracias
Reactions: Tj 0785
Was just about to ask the same
Reactions: S3AMJ
Sorry guys but the rubbers are no longer available from Audi, i got these mint secondhand ones as i noticed mine had been cut down as well
Nooooooooooo! Another part they no longer stock, god dammit. Thanks for the heads up mate, I’ll have to keep an eye out for a pair. I know they are not essential... but nors the battery cover or the engine cover, etc, etc. It’s all about that OEMnessssssss
Reactions: S3JACKSON
I am collecting a lot of parts now as many parts are going unavailable and the cars a keeper.
The two foam bonnet pads are no longer available as well:blue:
Reactions: S3AMJ
This is just a quick observation..... but me thinking that mine have been cut down, might not be case?! It seems from what I can see, the facelift had the shorter ones, covering just over the headlight. And the pre facelift had the ones that continued towards the bonnet catch.... I could be talking complete rubbish, just something I’ve noticed! Anyone else can confirm?
33
10
3K
61
6K
21
