What have you done today?
Just got off the phone from AH Fabrications I should have my V2 Intercooler by weds/Thurs Get it fitted then Saturday and up to Badger5 Tuesday for a map :)
Reactions: Pubemammal
Finally fitted the Facelift Vents this weekend, definately not a five minute procedure
Last look at the PFL Vents before removal
PFL Vent right
PFL Vent Left
after removal i had to use the soldering iron to pierce a hole in the venting and then made it bigger with a screw driver
Making the wiring hole
After feeding in the wiring i connected it to the led of the ashtray so that it also works with the interior dimmer
Wiring in
FL vents then fitted
FL vent in
and voila job completed
FL Vents Illuminated
Reactions: AdzA3AGU and jojo
what headlight switch are you using?
its an A6/S6 C5 FL headlight switch, requires quite an extensive bit of trimming to fit, i still need to make some minor trimming and adjustments before i'll be satisfied with the final fit
Reactions: IPG
Getting my turbo rebuilt and hopefully book in a remap slot sometime soon!
Rebuilding the turbo in the boot of my A6! lol I was suppose to get it rebuilt at the time of getting the CHRA, but my mate felt the hotside was too filthy, so took it away to shot blast it all clean, so the turbo is now fresh as a daisy for fitting! :)
Got my New AH Fabrications V2 on the Car Saturday and with some light modifications she is sitting lovely!!
FMIC
Also got new Tires up front as my inner Edges were a tad knackered, Went to the fitters with the idea of getting Toyo Proxes T1 Sports however when i got there they had a pair of ContiSportContact 5's to be sold at cost as someone had driven all of 5 miles on them and decided he dident like them and brought them back. £60 a tyre and they still had the fresh markings in them. So far a brilliant tyre, Gives excellent feel and turn in response but they are a tiny bit harsh at Motorway speeds
duff alternator removed,
cam belt and water pump replaced.
New alternator tomorrow with a new belt and tensioner then put her back together and check to see if I have a power steering leak.
then Holiday :)
Reactions: jojo
My trip to Badger5 yesterday was thankfully quite a success!!! More than impressed with what he has done with the car and it now drives Spectacularly! few bits to get for the car now such as a maf and a new fuel pump and then she will be right as rain until its time to go hybrid.
Also extra thanks to bill for increasing my knowledge on the 1.8T engines!!
Now for the bit you actually want to Read.
Dyno
Reactions: scotty_24
Fitted one 4mm macrolon (perspex) window before it started raining again.
One of the joys of living in Wales.....
Reactions: AdzA3AGU
Cleaning out this one
(plastic?) crap stuck in the suction pipe
Them stock rods... gotta change that
No joke - sump is cleaner than the interior LOL
Reactions: S3 Hilife and AdzA3AGU
Done the rear axle bush's and front brakes. Rear axle bush's took an hour and a half reasonable easy once I hammered them out.
s3/k04??? what's the process of removing the turbo without having to rip everything else apart?
Undo the manifold from the block with the turbo attached was how it came out on my S3. I'm also running a 3" down pipe, this was the easiest way?
I ask cuz I wanna port out my turbo and would rather not pull the head if I don't have to. I also have 3" DP. I'm all good disconnecting that after pulling the sub frame. After that I've not tackled anything further.
So assuming this is the way
- remove everything above to undo top DP nut
- get under and undo subframe and rack and let it dangle
- undo DP (remove?)
- undo mani
- undo tip & turbo oil and water lines
- Lift out mani and turbo as one???
I know most of the nuts on the driver's side are accessible. What about the ones behind the turbo?
Any special tools needed to detach the manifold?
- undo DP (remove?)
- undo mani
I wish I could answer you bud, but my mate is tackling it for me. He told me it was easy to undo the manifold and remove from the top. Exhaust and dp is still in situ, turbo was lifted off with mani as one unit.
Reactions: IPG
Took my car to AITP and put it on the ASN stand
Had some nice comments about the car which made my day
Some nice cars on the S3 Owners Group stand
Reactions: IPG
As I missed out on AITP again I thought I'd crack on with some pipework upgrades I had ordered a 63mm MAP pipe from Stuart at IWS Developments which replaces the restrictive OE pipe. I also ordered a 63mm-60mm reducing elbow, 63-70 reducing elbow, 70mm swaged alloy pipe (100mm long) a 70-64mm reducing elbow and a 70-80mm reducing elbow (for when 80mm tb is fitted)
Which kind of looks like this:
Pulled out the old, and took a comparison shot:
And set about trimming and fitting the new
Fits really well and should hopefully be a good improvement
Steve
What's your suspension set up?
Hey mate, it's got:
- H&R RSS Clubsport Coilovers
- Ground Control top mounts
- Tubular control arms front (IDF) and rear (Gruvenparts/Mad Max)
- Solid front subframe mounts (Tyrolsport)
- Solid steering rack mount (Tyrolsport)
- Rear rose jointed drop links
- Vibratechnics top engine mounts and ECS billet dogbone
- Team Dynamics Pro Race 1.2 17x9 ET15F/20R with Yokohama AD08R 235/40s
Not car related but started dismantling my pond I dug this out with just a shovel and graft! And built in in the evening after work was fairly big at 16000ltr but need garden back for little un it did get a proper rendering (mine fell off) but not pics of that
Reactions: S3JACKSON, scotty_24, GeorgieS3 and 4 others
I got a mk2 TT airbag cover off e-bay and a round airbag from a 6n2 polo and made a single stage airbag for my 8P S3 fbmfsw, I tried a few different vw/audi airbags before I found one the right size, it just needed an adapter bracket fabricated to mount the polo bag in place of the TT one.
Next job is to get the multi-function buttons to work the rns-e
Reactions: AdzA3AGU, Dohcwp and vanilla_ice
Front fog lights coming on with side lights
Dreaded window clip broken
Visited the trade counter at TPS today :sunglasses:
Reactions: Mav190sline
bit of this - bit of that
Relay added (above 53/100) for any accessories i want to run)
accessory 1
accessory 2 & 3 are mono block and 4 channel amp which are hidden :D
accessory 4
Reactions: Dohcwp
Lies lol
undo the 3 turbo to mani bolts then undo mani to head bolts remove mani undo everything else remove turbo from top why people remove the head is beyond me .... Should be fitted up soon mate just finding time
Reactions: IPG and jojo
Lies lol
Are you taking about s3 or a3???
I know on an a3 access is available to do that. S3 different story
Have removed K04 turbos from S3's 'easily' with not removing the head on the std manifolds... they are a little more awkward than K03's for sure but doable... probably getting confused with the work required to fit old relentless manifolds as they were a complete c*** to do...
<tuffty/>
Reactions: IPG and AdzA3AGU
The next Job, Turbo died last week due to the oil pump being a tad old i think.
33
10
61
6K
21
