indicator bulb replacement
and1g
shropshire
need to change my drivers front indicator bulb any tips on changein it ??? looks like there is no room to get your hand behind the headlight ;(
does the front bumper need to come off to remove the headlight ????
On pre-facelift lights, the indicator housing pops out
Yep as Dave said.... Although there is a holding clip that needs twisting. Above the indicator unit on the metal slam panel there is an access hole. Using a large long Phillips screwdriver, place down the hole and twist the clip 90degrees. Then push the unit forward to pop out.
cheers for the help guys got it sorted today :applaus:
Reactions: mark_S3
3K
I
10
imported_Wicked666
I
26
