Any ideas?
autolatry
Yorkshire
Think I have plugged few things in the wrong place...
Sunday,08,December,2013,14:35:06:44556
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
VIN: License Plate: SCAN 3
Mileage: 163980km-101892mi Repair Order:
Chassis Type: 8P (1K0)
Scan: 01 03 08 09 15 16 17 19 22 25 42 44 46 52 56
VIN: WAUZZZ8P54A074594 Mileage: 163980km/101892miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
Address 01: Engine Labels: 022-906-032-BDB.lbl
Part No SW: 022 906 032 CA HW: Bas isX 3
Component: MOTRONIC ME7.1.1 0005
Revision: 00000000 Serial number: AUX7Z0C7FNJ010
Coding: 0000172
Shop #: WSC 06435 000 00000
VCID: 4C912B162F651B7E38B-8019
12 Faults Found:
16486 - Mass Air Flow Sensor (G70)
P0102 - 002 - Signal too Low - Intermittent
17573 - Long Term Fuel Trim Additive Air; Bank 1; Range 1
P1165 - 002 - System too Rich - Intermittent
17499 - Mixture Regulation; Bank 2; Range 1
P1091 - 002 - Rich Limit Exceeded - Intermittent
17599 - Linear O2 Sensors: Before CAT
P1191 - 008 - Reversed - Intermittent
16395 - Bank 1: Camshaft A (Intake)
P0011 - 008 - ****** Setpoint not Reached (Over-Advanced) - Intermittent
16497 - Intake Air Temp. Sensor (G42)
P0113 - 002 - Signal too High - Intermittent
17951 - Angle Sensor 1 for Throttle Actuator (G187)
P1543 - 002 - Signal too Small - Intermittent
17580 - Angle Sensor 2 for Throttle Actuator (G188) Signal too Low
P1172 - 002 - - Intermittent
17763 - Cylinder 1 Ignition Circuit
P1355 - 004 - Open Circuit - Intermittent
17775 - Cylinder 5 Ignition Circuit
P1367 - 004 - Open Circuit - Intermittent
16502 - Engine Coolant Temp. Sensor (G62)
P0118 - 002 - Signal too High
16455 - Sensor for Ambient Air Temperature (G17)
P0071 - 004 - Implausible Signal
Readiness: 0010 1001
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-A.lbl
Part No: 1K0 907 379 E
Component: ESP ALLRAD MK60 0103
Coding: 0021128
VCID: 346153F6579563BE40B-8061
2 Faults Found:
00003 - Control Module
014 - Defective - Intermittent
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 C HW: 8P0 820 043 C
Component: KlimavollautomatH11 0130
VCID: 2C514B968FA53B7E18B-8079
2 Faults Found:
01317 - Control Module in Instrument Cluster (J285)
Freeze Frame:
Fault Status: 01101101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 148
Mileage: 163981 km
Time Indication: 0
Date: 2013.04.06
Time: 18:20:28
Freeze Frame:
ON
01206 - Signal for Duration of Ignition Off Time
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 148
Mileage: 163982 km
Time Indication: 0
Date: 2013.04.14
Time: 00:06:53
Freeze Frame:
Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 A HW: 8P0 907 279 A*
Component: Bordnetz-SG 1.0 H29 0501
Revision: 00029000 Serial number: 00000000173886
Coding: 018CCF01A0141000000000000000000000
Shop #: WSC 00000 000 00000
VCID: 3B7378CA7ACBACC6811-806E
Subsystem 1 - Part No: 8P2 955 119 C Labels: 1TX-955-119.CLB
Component: Wischer WWS Audi350 0180
Coding: 16711696
Shop #: WSC 00000
No fault code found.
Address 15: Airbags Labels: 8P0-959-655-84.lbl
Part No SW: 8P0 959 655 F HW: 8P0 959 655 F
Component: Airbag 8.4ED H01 0130
Coding: 0411602
VCID: 45871E320C0FEA36E75-8010
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 A HW: 1K0 953 549 A
Component: Lenksäulenmodul 009 0030
Coding: 0000012
VCID: 30695FE6A38D5F9E243-8065
Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
Part No SW: 8P0 920 980 J HW: 8P0 920 980 J
Component: KOMBIINSTR. VDO H25 0110
Revision: D06 Serial number: 2247CD06001010
Coding: 0005403
Shop #: WSC 00581 210 64475
VCID: 3E7571DE69D9B9EEA6F-806B
1 Fault Found:
00779 - Outside Air Temp Sensor (G17)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 00000011
Fault Priority: 7
Fault Frequency: 17
Reset counter: 148
Mileage: 163981 km
Time Indication: 0
Date: 2013.04.02
Time: 16:58:46
Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 B HW: 1K0 907 951
Component: Gateway H08 0090
Revision: 08 Serial number: 2400103805E43F
Coding: BD0F0340070101
VCID: 2645B9BE9149012ECEF-8073
Address 22: AWD Labels: None
VCID: 55A7CE72BCAF5AB6975-8000
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D06 Serial number: AUX7Z0C7FNJ010
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN1.lbl
Part No: 8P0 959 801 A
Component: Tuersteuerger. H10 0010
Coding: 0000048
VCID: 397F62C270F79ED693D-806C
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K2 909 144 D
Component: EPS_ZFLS Kl.10 1201
VCID: 2D574692B4BF32760F5-8078
1 Fault Found:
00778 - Steering Angle Sensor (G85)
000 - - - MIL ON
Freeze Frame:
Mileage: 3960 km
Count: 1
Steering Angle: 0.00°
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433
Component: KSG H02 0040
Coding: 198800186D288505485AC63000
VCID: F9FF22C2B077DED653D-80AC
Subsystem 1 - Part No: 1K0 951 605 A
Component: LIN BACKUP HORN H01 1201
Subsystem 2 - Part No: 1K0 907 719
Component: Neigungssensor 002 0002
Subsystem 3 - Part No: 8P0 951 177
Component: Innenraumueberw.H03 0010
1 Fault Found:
01134 - Alarm Horn (H12)
000 - -
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN1.lbl
Part No: 8P0 959 802 A
Coding: 0000048
VCID: 3A7D7DCE75F195CE9A7-806F
Address 56: Radio Labels: 8P0-035-1xx-56.lbl
Part No SW: 8P0 035 195 HW: 8P0 035 195
Component: symphony II EU H54 0400
Revision: 18S Serial number: AUZ5Z4C5310279
Coding: 0000201
VCID: EFEB1C9AFE338066FD9-80BA
End ---------------------------------------------------------------------
I did yeah. I did find an earth that wasn't earthed which got rid of a few codes. Then I scanned it again and thats what is above.
Ive dropped a ******* somewhere, I have two plugs with nowhere to go and I'm not confident a lot of the others are in the correct place. ***.
The camshaft one really concerns me seeing as the engine just been rebuilt... I've not started it yet, I wanted to clear all codes before i try.
Oh also, the large fan is constantly on when I turn the ignition on.
what at is the most upto date scan your fan running could be due to your cts not being connected ?
are you sure you have secured every earth
I've got plugs in the thermostat and radiator temp sensors and I was reasonably confident they were correct. If the wrong plug is plugged in could it be constantly sending current to it?
Or sending the wrong signal to the ecu should I say
Most plugs are different sizes or slightly differently shaped to avoid mix up's however if it is possible it would baffle the ECU is the earth above the vvt solenoids ok
getting there. does anyone know where the sensor G17 is on the car? cant seem to see it around front of the car.
Friday,13,December,2013,19:05:37:44556
VIN: License Plate: LATEST
03-ABS Brakes -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
Coding: 0000172
1 Fault Found:
Readiness: 0110 1101
Coding: 0021128
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 148
Mileage: 163981 km
Time Indication: 0
Date: 2013.04.06
Time: 18:20:28
Freeze Frame:
ON
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 148
Mileage: 163982 km
Time Indication: 0
Date: 2013.04.14
Time: 00:30:50
Freeze Frame:
Coding: 16711696
Shop #: WSC 00000
Coding: 0411602
Coding: 0000012
Coding: 0005403
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 18
Reset counter: 148
Mileage: 163981 km
Time Indication: 0
Date: 2013.04.02
Time: 16:58:46
Address 22: AWD Labels: 1K0-907-554.lbl
Part No: 1K0 907 554
Component: HALDEX 4Motion 0101
Coding: 0000001
VCID: EADD0D8EC5D1654EAA7-80BF
Coding: 0000048
1 Fault Found:
000 - - - MIL ON
Freeze Frame:
Mileage: 3960 km
Count: 1
Subsystem 1 - Component: Sounder No Answer
1 Fault Found:
004 - No Signal/Communication
Coding: 0000048
Coding: 0000201
getting there. does anyone know where the sensor G17 is on the car? cant seem to see it around front of the car.Friday,13,December,2013,19:05:37:44556VCDS -- Windows Based VAG/VAS EmulatorVCDS Version: 12.12.0.0Data version: 20130910VIN: License Plate: LATESTMileage: 163980km-101892mi Repair Order: Chassis Type: 8P (1K0)Scan: 01 03 08 09 15 16 17 19 22 25 42 44 46 52 56VIN: WAUZZZ8P54A074594 Mileage: 163980km/101892miles00-Steering Angle Sensor -- Status: OK 000001-Engine -- Status: Malfunction 001003-ABS Brakes -- Status: OK 000008-Auto HVAC -- Status: Malfunction 001009-Cent. Elect. -- Status: OK 000015-Airbags -- Status: OK 000016-Steering wheel -- Status: OK 000017-Instruments -- Status: Malfunction 001019-CAN Gateway -- Status: OK 000022-AWD -- Status: OK 000025-Immobilizer -- Status: OK 000042-Door Elect, Driver -- Status: OK 000044-Steering Assist -- Status: Malfunction 001046-Central Conv. -- Status: Malfunction 001052-Door Elect, Pass. -- Status: OK 000056-Radio -- Status: OK 0000 -------------------------------------------------------------------------------Address 01: Engine Labels: 022-906-032-BDB.lbl Part No SW: 022 906 032 CA HW: Bas isX 3 Component: MOTRONIC ME7.1.1 0005 Revision: 00000000 Serial number: AUX7Z0C7FNJ010 Coding: 0000172 Shop #: WSC 06435 000 00000 VCID: 4C912B162F651B7E38B-80191 Fault Found:16455 - Sensor for Ambient Air Temperature (G17) P0071 - 004 - Implausible SignalReadiness: 0110 1101-------------------------------------------------------------------------------Address 03: ABS Brakes Labels: 1K0-907-379-MK60-A.lbl Part No: 1K0 907 379 E Component: ESP ALLRAD MK60 0103 Coding: 0021128 Shop #: WSC 06435 000 00000 VCID: 346153F6579563BE40B-8061No fault code found.-------------------------------------------------------------------------------Address 08: Auto HVAC Labels: 8P0-820-043.lbl Part No SW: 8P0 820 043 C HW: 8P0 820 043 C Component: KlimavollautomatH11 0130 Shop #: WSC 06435 000 00000 VCID: 2C514B968FA53B7E18B-80792 Faults Found:01317 - Control Module in Instrument Cluster (J285) 013 - Check DTC Memory Freeze Frame: Fault Status: 01101101 Fault Priority: 3 Fault Frequency: 1 Reset counter: 148 Mileage: 163981 km Time Indication: 0 Date: 2013.04.06 Time: 18:20:28 Freeze Frame: ON01206 - Signal for Duration of Ignition Off Time 008 - Implausible Signal Freeze Frame: Fault Status: 01101000 Fault Priority: 3 Fault Frequency: 1 Reset counter: 148 Mileage: 163982 km Time Indication: 0 Date: 2013.04.14 Time: 00:30:50 Freeze Frame:-------------------------------------------------------------------------------Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl Part No SW: 8P0 907 279 A HW: 8P0 907 279 A* Component: Bordnetz-SG 1.0 H29 0501 Revision: 00029000 Serial number: 00000000173886 Coding: 018CCF01A0141000000000000000000000 Shop #: WSC 00000 000 00000 VCID: 3B7378CA7ACBACC6811-806E Subsystem 1 - Part No: 8P2 955 119 C Labels: 1TX-955-119.CLB Component: Wischer WWS Audi350 0180 Coding: 16711696 Shop #: WSC 00000 No fault code found.-------------------------------------------------------------------------------Address 15: Airbags Labels: 8P0-959-655-84.lbl Part No SW: 8P0 959 655 F HW: 8P0 959 655 F Component: Airbag 8.4ED H01 0130 Coding: 0411602 Shop #: WSC 06435 000 00000 VCID: 45871E320C0FEA36E75-8010No fault code found.-------------------------------------------------------------------------------Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl Part No SW: 1K0 953 549 A HW: 1K0 953 549 A Component: Lenksäulenmodul 009 0030 Coding: 0000012 Shop #: WSC 06435 000 00000 VCID: 30695FE6A38D5F9E243-8065No fault code found.-------------------------------------------------------------------------------Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl Part No SW: 8P0 920 980 J HW: 8P0 920 980 J Component: KOMBIINSTR. VDO H25 0110 Revision: D06 Serial number: 2247CD06001010 Coding: 0005403 Shop #: WSC 00581 210 64475 VCID: 3E7571DE69D9B9EEA6F-806B1 Fault Found:00779 - Outside Air Temp Sensor (G17) 010 - Open or Short to Plus Freeze Frame: Fault Status: 00000011 Fault Priority: 7 Fault Frequency: 18 Reset counter: 148 Mileage: 163981 km Time Indication: 0 Date: 2013.04.02 Time: 16:58:46-------------------------------------------------------------------------------Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb Part No SW: 1K0 907 530 B HW: 1K0 907 951 Component: Gateway H08 0090 Revision: 08 Serial number: 2400103805E43F Coding: BD0F0340070101 Shop #: WSC 06435 000 00000 VCID: 2645B9BE9149012ECEF-8073No fault code found.-------------------------------------------------------------------------------Address 22: AWD Labels: 1K0-907-554.lbl Part No: 1K0 907 554 Component: HALDEX 4Motion 0101 Coding: 0000001 Shop #: WSC 00000 000 00000 VCID: EADD0D8EC5D1654EAA7-80BFNo fault code found.-------------------------------------------------------------------------------Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb Part No SW: 8P0 920 980 J HW: 8P0 920 980 J Component: KOMBIINSTR. VDO H25 0110 Revision: D06 Serial number: AUX7Z0C7FNJ010 Shop #: WSC 00000 000 00000 VCID: 3E7571DE69D9B9EEA6F-806BNo fault code found.-------------------------------------------------------------------------------Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN1.lbl Part No: 8P0 959 801 A Component: Tuersteuerger. H10 0010 Coding: 0000048 Shop #: WSC 06435 000 00000 VCID: 397F62C270F79ED693D-806CNo fault code found.-------------------------------------------------------------------------------Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb Part No: 1K2 909 144 D Component: EPS_ZFLS Kl.10 1201 Shop #: WSC 00000 000 00000 VCID: 2D574692B4BF32760F5-80781 Fault Found:00778 - Steering Angle Sensor (G85) 000 - - - MIL ON Freeze Frame: Mileage: 3960 km Count: 1 Steering Angle: 0.00°-------------------------------------------------------------------------------Address 46: Central Conv. Labels: 8P0-959-433.lbl Part No: 8P0 959 433 Component: KSG H02 0040 Coding: 198800186D288505485AC63000 Shop #: WSC 06435 000 00000 VCID: F9FF22C2B077DED653D-80AC Subsystem 1 - Component: Sounder No Answer Subsystem 2 - Part No: 1K0 907 719 Component: Neigungssensor 002 0002 Subsystem 3 - Part No: 8P0 951 177 Component: Innenraumueberw.H03 00101 Fault Found:01134 - Alarm Horn (H12) 004 - No Signal/Communication-------------------------------------------------------------------------------Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN1.lbl Part No: 8P0 959 802 A Component: Tuersteuerger. H10 0010 Coding: 0000048 Shop #: WSC 06435 000 00000 VCID: 3A7D7DCE75F195CE9A7-806FNo fault code found.-------------------------------------------------------------------------------Address 56: Radio Labels: 8P0-035-1xx-56.lbl Part No SW: 8P0 035 195 HW: 8P0 035 195 Component: symphony II EU H54 0400 Revision: 18S Serial number: AUZ5Z4C5310279 Coding: 0000201 Shop #: WSC 06435 000 00000 VCID: EFEB1C9AFE338066FD9-80BANo fault code found.End ---------------------------------------------------------------------
The g17 is the ambient air temp sensor clipped to the radiator cradle it gives you the temp on your cluster can't remember what side what was the cause of all the other codes ?
717
540
652
903
