DJAlix
VAG CAR CODING
Site Sponsor
VAG Can Professional
ODIS (Offboard Diagnostic System)
Indeed! A few too many Bulgarian Merc's and BMW's knocking around in Touzla this year tho lolHave a nice vacation! Nothing like a frappe at the balcony, late in the afternoon after a day at the beach!
www.homecareshop.gr
Thanks Sean! Added to the listHi DJAlix,
I noticed a small error in the Static Cornering Lights mod in your document.
Under Step 7, the correct adaptation channel should end with B13, instead of B12.
Also, you may put a note to ensure step 6 and 8, the user selects Abbiegelicht, instead of Abblegelicht. Very easy to make this mistake especially on a netbook with a small screen since "i" and "l" looks almost the same.
Lol. That's one good reason why I want the mirror dip mod.Anyone have the code to hand to stop the handbrake from being applied when you're reversing and open the drivers door to check how close you are to the kerb ?
To be honest I am not sure as this is not something I have had reason to play with as yet.Alex, do you have any idea what exactly 17-Instruments Long Coding Byte 8, Bit 0-7 is for?? It's supposed to be Display Language selection, but for what do you know? My MMI menu and everything else is set to English, with VCDS Byte 8, Bit 0-7 shows only 2 language options, 00 German and 01 English... But with ODB11, it shows like tons of other language and it shows I'm using Chinese (Canto) for whatever reason... And I'm sure it's right too, since my MMI menu only has English and Chinese to select from...
Page 112 of your owners manual.Do you know how to active launch control on audi A3 8v 1.8 tfsi FWD?
Thanks I try with all things but it doesn't works, I think my car don't have the program. how can i install that program? its 1.8TfsiPage 112 of your owners manual.
To be honest I am not sure if it would be possible. It could be coding that has not been labeled as yet or it could be firmware related. If firmware related then you would need ODIS or Vag Can Professional and the needed files.Thanks I try with all things but it doesn't works, I think my car don't have the program. how can i install that program? its 1.8Tfsi
A link to the document is normally within my signature but I am in the process of porting it to my website. Updates soon!@DJAlix
Where do I find the latest version of your document / list?
Also, if I remember correctly, date and workshop id is logged when changing settings with diag instrument...
Is there any - significant - risk of getting a TD1 due to vcds mods?
The vacation pic looks lovely btw!
Envy you very much since were 'grounded' at home during the rest of vacation after cat injury...
Changes would only get wiped / reset buy Audi if they need to perform a software update. My experience has been that as long as you are not messing with "physical" changes, to brakes for example, Audi will not complain or for the most part even noticeI have done it on all my audis...never changed anything back before service and never got any TD1. But I have noticed sometimes that when they sync the settings to Audis server it changed some values back to original. But never TD1. But I guess if they want they could!?
VCDS should never generate a TD1 code, but unless you know 100% what you are doing never mess with anything you are not sure about... thats the way I always approach things anyway lol
Possible Vehicle Warranty Code and Data Displays / Flags:
With the exception of 3 and 4 the other flags should only be generated if there is an unexpected software version found while Audi is scanning / performing Software Version Management. VCDS cannot update software.
- TD1 = Modification to engine control unit
- TG1 = Modification to gearbox control unit
- TE1 = Modification to power electronics
- TB1 = Suspected tuning with tuning box
Back in the UK now, from 37c to 18c Hope your cat is ok...
http://www.ross-tech.com/vcds/revisions.phpso I just got an update to the vcds software. does anyone know what new stuff is added?
First possible issue that springs to mind is drivers. I would try reinstalling VCDS.I update my original vag-can to vcds 16.8 version and now I have problems to make a simply autoscan. Before (in older versions) its works very well.
Anyone more?
Have you tried removing the key first? My Australian A3 will light up the left or right parking lights depending on which way you indicate once you have removed the key.I am trying to see if the European A3/S3 owners have the parking light function enabled in their vehicles? When you park on a dark street, you simply flick the indicator stalk to right indicate and remove the key. The right side front and rear parking lights will illuminate which helps other vehicles to see your's better.
This function appears to be disabled for my car in Australia. I was wondering if it can be enabled via VCDS?
I have the coding for this, just need the time to look for it. Will have a look this evening and post it upI am trying to see if the European A3/S3 owners have the parking light function enabled in their vehicles? When you park on a dark street, you simply flick the indicator stalk to right indicate and remove the key. The right side front and rear parking lights will illuminate which helps other vehicles to see your's better.
Which Headlights do you have?Moonstone, yep, tried it with key out. I had the same feature in my MK5 Jetta previously, so not a stranger to this useful feature. I am surprised that it isn't enabled in my car, but I can't seem to find any reference to this in the user manual.
DJAlix, thanks! Much appreciated if you can post up the coding for it.
No worries. Glad I could help.Moonstone, I will have to swallow my words! I went out to try it again, and it worked! Switch off car, pull key out and flick the indicator stalk to right.
Awesome you took the plunge! Did you get the virtual cockpit in too?Need a favour if possible
Was wondering if anyone with a new facelift car and the MMI/MIB TechPack version 2 (apple carplay / android auto) and VCDS would be willing to make and Adaptation Map of 5F, or if London based allow me to pop over so I can make one?
I have an MMIv2 retrofit / testing project on the go. All is in and working fine, I believe) but the unit has been coded from scratch and I am keen to compare my works to how the factory coding and adaptations from Audi are.
It's in a test car Existing TechPack Screen and Controls can be used, FL steering wheel not needed. Huge upgrade from an MMI Std unit, Nice upgrade from pre-FL but all you are really gaining is speed and Apple / Android integration, oh and no need for stupid AMI cables anymore and it's USB based.Awesome you took the plunge! Did you get the virtual cockpit in too?
Sent from my SM-N910V using Tapatalk
Virtual Cockpit project is on hold. The retrofit process is actually straight forward but the problem is that Audi HAS to be involved due to the need for immo and key coding, which as you can imagine adds up to a pretty large cost... £1800 to £2500k retrofit (resale). Finding a dealer willing to do the work is another problem.
Am looking to test one of these also, very cost effective for the features (including Nav).I was wondering about the difficulty of the VC because dealer help (hard enough to get ADS coded on my car). Wanted Android Auto for years, but ended up putting a full android system which ive been loving.
But awesome work as always and looking forward to seeing the end results!
