You dont have to take the headlight out the round plastic covers come off to get into the headlight surround, use a long screwdriver flathead and gently pry the plastic holder away and you can remove the old 501 bulb and fit a canbus error free bulb good luck there are some good guides on here if you search. Mike
If you need to remove the headlight then you have to remove the front bumper. If your just changing the bulb then if just a pain as there is not much room.
there is really no need to remove the bumper it is however hard to remove the side light bulb but possible I just pulled the 2 wires as it is very difficult to get a grip of the actual bulb they will pop out having someone with small hands is an advantage though lol
