Hi guys,
I have been looking on the net for a while now but I have been unable to find a 'how to guide' for the removal and replacement of the N75 valve on a S3. I know its attached to the turbo but how are you supposed to get access to change the damn thing. I have been under the car and removed the under tray but the route to blocked by what looks like a heat shield along with other engine components.
I'm changing the valve as my car has developed a power spike around the 3300rpm mark. I cannot be sure if the valve is responsible but it cannot hurt to change it (I have also swapped the DV valve to a version 'D') My car runs fine and I have no error codes or warning lights displayed.
If anyone has any ideas what maybe causing the spike I'm all ears. Below is the dyno print out.
Note: I have had the car remapped recently in an attempt to iron out the spike but it has made the spike worse. Anyway my car is stock expect the stage 1 map.- 2007 plate with 40 odd thousand on it. The cam belt has also been changed within the last 6 months.
Jimmy
Jimmy
