- Joined
- Oct 13, 2009
- Messages
- 4,595
- Reaction score
- 1,272
- Points
- 113
- Location
- Stoke On Trent
- Website
- www.businessguysit.com
Is this the one associated to the Golf which wasn't really workable on the 8P?
Veeeight posted a link to a kit on a 8V
Wish the hatch had this, but I do know there is a retrofit around.
...doesn't it? My Sportback does...
It opens too if you hold the button down, but the lid won't flip all the way open, it's too heavy for that! Saloon boot lids are generally sprung to fly open when they are released.
I am massive fan or the Bare Naked Ladies BNL. Seen them loads of times cannot wait to have it playing in my new A3Dissappointingly, nothing from the MMI seems to get saved, which means I get blasted with One D or Bare Naked Ladies whenever I turn the ignition on.
When I received my serviceplan documentation it had a little booklet with a number of small features not mentioned in the handbook. I will share if anybody is interested.
Stop/Start system activation can be regulated by brake pedal pressure/travel, if you lightly hold the foot brake (enough to stop creeping forward) then the Stop/Start will not activate, when you push a bit harder the engine will stop. So if you are in err in Stop/Start traffic and don't want the system to engage then light pressure will not activate the system. I know you can turn it off on the dash but I have kind of got used to it now and generally like it operation.
It will be interesting in years to come to see if Starter Motor failures appear as a gripe, not sure if the motors have been beefed up to copy with a 100 times (minimum) usage increase. The system that is used on some Mazdas is pretty cool as they use combustion pressure to spin the motor back up one it has been running via an accumulator.
All components associated with S/S have been updated. The battery is AGM, physically the size of the starter motor is increased compared to the 8P, and the motor mounts have been re-enforced for S/S duty.It will be interesting in years to come to see if Starter Motor failures appear as a gripe, not sure if the motors have been beefed up to cope
Yes you are correct, there is a difference in clutch clamping pressure and bite point between the 2 brake pedal positions.But if you don't press down fully on the brake pedal I've noticed that the revs don't drop so much as if you do and I assumed that the S-Tronic is not releasing its clutch fully. Is that correct or am I imagining it? If it doesn't then it's surely putting extra strain/wear on the clutch.
More: Click -> audi s3 start stop feature
a light pressure means that you can creep forward (s-tronic box).
/QUOTE]
Something that I can do on the 8P may also work on the 8V. Turn the car on (engine off) and press the brake until the brake lights come on - point 1. Now with your palm resting on top of the shifter (S-tronic) keep pushing on the brake until you feel a slight vibration in the shifter - point 2. Next turn on the engine, push the brake until point 2 and hold the brake while you shift into drive. The car should creep forward while you hold the brake pedal at point 2. Point 2 is a good reference point to test the DSG.
That said my favourite little extra (thanks whoever posted it above as I hadn't noticed) is the boot lights that move to hold the floor in the up position.
If you don't have hold assist, you can as alternative use electronic parking brake on inclines, it also seems to work well. When used, the epb does not disengage until car has enough forward momentum to stop rolling back.
I've read manual but can"t seem to find any info about tyre pressure monitor display. Can anyone assist with advice, thks. My car is an A3 Sportback 1.4 TFSI S-tronic with a few options including 17" wheels which are a bit different and lower in profile than my previous A3 15" which were higher profile.
It was a BIG surprise to me, that the A3 did not have :
a little sun visor above the rear view mirror, like the 8P has.
This made driving towards the setting sun very unpleasant.
It's not on the S3 either
If we are talking about negative surprises then I am surprised that with all the tech and connectivity in the car you can't see where the car is at any given time!
I thought that but then they are stepping on the toes of dedicated trackers and they sell trackers in the accessory brochure.
lol had my car 4 months and never knew thatYea it's actually 2 jackets in there . And of course your reflective triangle in the boot lid
Also nice: entering the car with an iPhone charged < 20%, the MMI notifies you to charge it!
Still like doing this even after 5 1/2 years with our A4 S-line. Wife says I'm a bit sad ...Yeh, I love looking at the reflection of the LED DRLs in the back of the car in front!
