1.9 TDI EGR question - Gasket?
Chrismawa
Tyne and Wear
I want to clean my EGR valve this week. When I remove it is there are a gasket I will need to renew when refitting? Car is a 2002 awx. Cheers.
I was told by another member to renew the O ring seal between the EGR and inlet manifold, as mine was leaking there anyways:
http://m.ebay.co.uk/itm/331072447632?nav=SEARCH
If you want you could replace the gasket at the top of the gold pipe to one with a smaller hole from a MK3 Ibiza! But with yours being a 2002 you could maybe blank the EGR without the EML coming on?
I'd clean out the inlet manifold too when your in there! :)
EGR Cleaning (1.9TDi 130):
•Rubber 'O' Ring seal - SN90927302 - £4.04 at TPS.
•EGR Gasket - 069131547D - £2.41 at TPS.
Reactions: Chrismawa
772
889
3K
13
