WillHarris2306
My 2008 A3 1.8T FSI 160 has started developed a hissing noise from the footwell when engine running and not braking (i.e. goes away when you depress the brake pedal). Brakes still feel ok. Sometimes very slightly lumpy on idle but generally it's smooth.
Tried to get as much info from the forum as i possible and the general consensus seems to be these symptoms indicate either servo or vacuum hose failing / split. If servo i'm reading horror stories of it being a big (6-10 hours) job as it's so hard to access and some members are saying it involves dropping the engine or at least loosening the mountings etc!! However i'm also hearing this from mainly S3 or Diesel owners so i'm wondering if the same applies to the humble 1.8T FSI?
I'm going to have a close look at the hose today and i'm hoping it's only that, but generally my luck's not that good. Any advice would be much appreciated but it sounds like it has servo written all over it.
P.s. forgot to mention (although it's a long shot) the car does have cruise control which i read on a US VAG forum strangely can create this noise as the system is somehow interconnected via a vacuum hose so it deactivates when you brake. May be b*****ks but just thought i'd mention it.
