Parts Database for the A4/S4
Sandra
Administrator
Staff member
Administrator
Audi Main Dealer
Platinum Supporter
So here's GOLDEN/PRECIOUS information for ALL A4 owners, especially those of the hands-on variety...
In my post-box yesterday morning was a link to the AUDI RS3 SPORTBACK, but following that I found this:
AUDI A4/AVANT [A4] (EUROPE) 1995-...
Within ARE links to illustrated parts lists for the Audi A4, S4 etc, 1997 to date, go check... :readit:
And as it's ALL FREELY available information...
Courtesy of @45bvtc
Reactions: IRONy_MAN, johnnythepie, Anthony566 and 4 others
Hi yer Princess Sandra
sorry to dampen your enthusiasm with the little nugget of information but a word of warning as an owner of a B6 cab 05 plate with a B7 interior I have seen upgrade mods on line to the centre console, from the one fitted to my car to the last one with the 2 cup holders before the B7 became the seat exeo
partsbase.org pictures show the centre console picture's from 05 as exactly the same to 12 plate exeo so why didn't they upgrade the information for each model it could be the same part numbers are the used I'am currently working on this (with the help of some of the lads at Taunton Audi) but also some of the numbers on the pictures are different
hope this helps I could be making a stupid mistake and not realised it so if you could shed any light on this lol
I want to know about the 3 A4 air vents in the centre could you ask you other learned friends was the 3 round air vents only fitted to convertiable I only ask because I've see 06 and 07 Saloon's and Advants with the 3 round vents but also with the long square vents did it depend on the model ?????
thanks Si
Cheers andra, some excellent info and illustrations in there:beerchug:
Reactions: Sandra
the round vents were only fitted to the cab
but some people retrofit the saloon or avant dash to the cab and have the square vents.
Has any one on here ever changed the headlights on there se a4 b8 to the xenon led headlights out of the sline. Is this possible or has anyone done this
yes I have its very easy
you need the loom and vcds coding
and maybe a ECM to work the high beam some need it some don't
Is it expensive for the looms and vcds coding.? Plus did you have any trouble with mot of the car as some people have advised me that you need to install washer jets into the bumper
loom is £50 ish vcds I do myself but a local member with vcds will help you out for beer tokens
and you do really need washers etc etc but I don't have a problem with MOT.
