Audi S3 boost problems
goodbuzzman1
When i picked up my s3 a few weeks ago i knew it would need a bit of work. ive sorted most of the problems but one remains.
The boost seems to be a bit intermittent.
so far i have checked for boost leaks. i found that there were leaks in a few breather pipes and also a small leak in the turbo intake pipe.
I replaced all the offending pipes with nice new silicone ones at the weekend but there till seems to be random hesitance when i put the foot down. sometimes it pulls like a train and other times it stutters and then boosts.
When i was replacing the TIP, i did notice a slight bit of play in the turbo left to right.
Ive also been doing a bit of reading about the N75 valve so this evening i unplugged it and went for a spin.
I have to say, the car felt like it had only 120hp but it was absolutely smooth all through every gear.
does this mean the valve is good or bad :)
ANy help on what to do next would be much appreciated
cheers
If you unplug the N75 you'll be boosting to around 6psi.. Hence why it feels about 120bhp - I'd try swapping the N75 and see if it makes a difference. Was the first thing I had to replace on my S3.
I will be giving it a scan this evening. I just wanted to repair the obvious boost leaks before i did
Ok. So i scanned the car this evening and it didnt give me any fault codes (apart from one for the radio antenna)
I tested the diverter valve and that seems to be ok.
What i did notice was that the pipe that goes from the diverter pipe over to the turbo pipe is suffering from the same heat related collapsing as all the other ones i have just replaced. One of the bends is especially bad and i cant imagine much can flow through it. but how much affect could it have? enough to affect performance?
568
17
22
