- Joined
- Mar 24, 2007
- Messages
- 2,072
- Reaction score
- 791
- Points
- 113
- Location
- Oxfordshire
- Website
- www.audi-sport.net
Alu frame, and glossy black honey comb would look great.
Tempting
I like the alu with the blue and agree with the fog grills with alu surround will tie everything together. I am tempted to paint my splitter and rear diffuser LAP6(alu matt)
I'd be interested in what you think of the PS4s
I need some winter boots soon.
Ps4 are incredible tyres. so impressive on wet and rain. They just grip like it's dry!!.
had a great drive out today for an hour and a half and it bucketed it down, the PS4s ignored the standing water excellently, no pull whatsoever, braking excellent to. Direction and turn in great can't fault them
You need to remove the rs3 from the badge holder then cut it at an angle to match other side. Then attach the S3 and then attach it to the grill
3M tape mate! You take the S3 logo off too and then use 3M tape to attach the S and 3 to the RS badge holer
Got it. Does your grille have a removable number plate holder? Want to convert mine if I can.
Chrome god surrounds fitted
Couldn't help it....what's a god surround!
I want one.
Amen to that!Couldn't help it....what's a god surround!
I want one.
It seems that most modern cars are not designed to have serviceable lightbulbs on the side of the road, which I always found to be a bit odd. I spent a solid 40 minutes helping a friend replace a blown bulb on a Honda Jazz last year - also had to go through the wheel arch, which was a right nightmare.
Is the improvement you saw mostly in terms of brightness, light temp or has the pattern improved too? I'd imagine that the latter is more down to the reflectors mostly. Would be interesting to see the difference side-by-side as I also think that my lights could be improved, although in my case it's mostly down to the light pattern rather than the brightness. Might see if I can get mine adjusted by someone more competent and with proper equipment at some point.
Just read through all 17 pages, and it's a great thread, some brilliant ideas and images to help, I've got a long list of things I want to do to mine and have taken a lot of ideas! Look forward to reading more
Do you have a link buddy ?
Do you have a link for the surrounds?
New bit turned up but not as simple as I thought, trimmed edges with sander to fit hole, went well, got it plugged in and fired up and worked fine.
Problem when pushing into place the metal tabs don't locate properly, having checked the back of the unit it looks like there is a lip on the bottom of the old unit that is missing on the new one. This is the only difference so must be the problem.
Back to the drawing board
Looks like I need T9 bit / screwdriver to swap the backs over, trust my luck Ive got 5,6,7 then 10!!!!!
Must say it definitely looks better and matches the dash all the heated seat buttons are much better then those fiddly dials
Are there still 6 settings on the heat adjust or is it just 3 with the new switches?
How hard was the cruise control retrofit|?
I've been thinking about getting my climate control module swapped out too. Other than the colour, the seat heating controls are my next biggest gripe with it. The wheel is pretty fiddly and looks like button is a much better way to control them even if it's just three settings.
I better set up some eBay searches to hunt for one of these
Sent from a mobile device, please forgive typos
