where can i get 06A 133 784H pipe at end of injection mani
epox
Glasgow
hi any ideas where i can get this pipe local tps cant find it!
nice hissing sound and g/s down from 218 to to 205
thanks
mark
I think it may just come with the full kit... not unusual for TPS not to find it as the part number may have changed a bit (normally the letter on the end).. Either do a PCV delete and bin off all or look at getting the Forge one
Forge Motorsport | Alloy Fabrication
If I remember I'll have a look on ETKA later to check the PN
not completly the same but it should do !
thanks
mark
Its not going to be mate... the actual V pipe is the same as the forge part... the bit at the top is for the servo vacuum and can be seperated from the V hose
Have had a hunt about on ETKA and found the pipe listed under the TT... it would appear its not available separately... seems its part of the plastic pipe setup and looks to be PN 06A 133 789 C
Also suggests its at least 60/70 quid
cheers tuffty,
the top part of the v is only a support for the v pipe aafter looking at it the vacume pipe hard plastic passes through this bit and the u hose connects after this support part.
have superglued the split for a temp repair just now.
thanks for the help.
mark
