LuisM
Hi all,
I keep reading you should store the tyre pressure (via the MMI) every time you inflate your tyres. Is that so? And why?
An example. Let's consider you stored your ideal pressure (say 2.2 bar) in the MMI. A few weeks later you check the tyres. Pressure is a bit low (but not very much, because the car hasn't warned you yet). So you inflate tyres to your ideal pressure (2.2, the same that was stored). At this point, why should you store again? You will be storing the same value that was already stored.
It would make more sense to me if you had to store only when you change pressure. For example, you inflate to 2.4 for a long highway trip with heavy baggage. Since the target value for the MMI is no longer the previously stored 2.2, now it makes sense that you should store the new value.
Any ideas?
Any ideas?
