hi... i'm a newbie and as as you may notice this is my first post. Hopefully i will be in position to add more value in the future for someone else's issues rather than my own ones but here it is ...
i did quick scan on my car over the weekend and it returned an error related to battery regulator. i do not use car very often (Weekends mainly) and do notice that after couple days of non starting it is struggling to 'turn on'. I checked the battery at several places and they advised that it is fine... however when plugged to VCDS it reports an error. So... Has anyone got any hints on how to 'interpret' this error for better terms so as to determine what is wrong with the car that relevant part can be ordered/rectified? i also did some detailed assessment of the battery and have attached those too.
Any assistance is welcomed...
Saturday,31,May,2014,15:05:46:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Control Module Part Number: 4F0 910 181 F HW: 4F0 915 181 B
Component and/or Version: J0644 BEM H13 0760
Software Coding:
Work Shop Code: WSC 04008 758 999999
Additional Info: 4F0915105D von VA0 2712110813
Additional Info: Geraet 999999
VCID: 24470A1BE72E243ED0B-8071
4 Faults Found:
02273 - Quiescent Current Stage 2
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 3
Reset counter: 255
Time Indication: 0
Date: 2014.01.05
Time: 17:11:03
02479 - Partial Consumer Shut-Off Active
Freeze Frame:
Fault Priority: 7
Fault Frequency: 255
Reset counter: 255
Time Indication: 0
Date: 2012.11.29
Time: 17:57:51
02272 - Quiescent Current Stage 1
Freeze Frame:
Fault Priority: 7
Fault Frequency: 40
Reset counter: 255
Time Indication: 0
Date: 2012.12.12
Time: 14:46:49
02274 - Quiescent Current Stage 3
Freeze Frame:
Fault Priority: 7
Fault Frequency: 9
Reset counter: 255
Time Indication: 0
Date: 2012.12.19
Time: 21:52:00
Many thanks... Dan
Software Coding:
4 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 255
Time Indication: 0
Date: 2014.01.05
Time: 17:11:03
Freeze Frame:
Fault Priority: 7
Reset counter: 255
Time Indication: 0
Date: 2012.11.29
Time: 17:57:51
Freeze Frame:
Fault Priority: 7
Fault Frequency: 40
Reset counter: 255
Time Indication: 0
Date: 2012.12.12
Time: 14:46:49
Freeze Frame:
Fault Priority: 7
Fault Frequency: 9
Reset counter: 255
Time Indication: 0
Date: 2012.12.19
Time: 21:52:00
Many thanks... Dan
