So as you may or may not know, I sent my turbo off to be reconditioned only to be told the housing was cracked. So I have sourced a new turbo and will be fitting it soon however,
the guy who was talking to me about the turbo said that it cracked possibly because of something to do with the cat? Something about not enough flow causing the turbo to heat up and crack? Is this a possible cause? I just want to make sure before I take the cat out as all the downpipe to cat bolts are non existent due to rust and will have to be cut off
im also replacing the egt sensor as this kept throwing up faults codes. Could this contribute?
