A4 SE Technik - Dynamic Suspension
mikeav6
Hello
Whilst excitedly watching the days pass waiting for my new Audi to be delivered, I was playing around on the configurator. In doing so I noticed that the SE Technik is now listed as having Dynamic Suspension:
ImageUploadedByTapatalk1402234658206375
What does this mean as having read around on the internet it would suggest that it is the adjustable set up via drive select. Or does is dynamic suspension just the term used to describe the standard set up?
Hi Mike dynamic suspension as part of the Audi drive select should give you a range of options between comfort and dynamic. You should be able to set to suit the driving conditions or your mood!
I hope so although the spec also says 'without drive select'. I'm curious as to whether it is any lower than standard suspension as well.
I asked the dealer the same question about the suspension when I ordered mine week before last was told it is standard or I could have sports suspension as option which is same as the s-line (20mm lower). I went for the sports suspension
