Just getting around to replacing the throttle actuator unit on my 2.0 Tdi (BKD).
I've removed the EGR unit and air intake manifold to clean/de-coke, but am unsure what to use on the manifold... there's a raft of conflicting advice out there - some recommend using Mr Muscle Oven Cleaner Foam, whilst others state this is a no-no as the product contains compounds unsuitable for use with aluminum. I don't want to go the gas canister and oxygen 'red-neck' way as this looks way too brutal.
Can anyone recommend a suitable product(s) - obviously, it'll need to work effectively in the many inaccessible areas of the manifold to avoid the risk of partially removed/dislodged deposits being drawn-into the engine on reassembly and start-up... Mr Muscle does seem to work well - especially when blown-through with a jet wash after use, but ignoring the warning on the can 'Unsuitable for use on/with aluminum' is surely advice that's not to be ignored?
