Yes and with no problems. Details of what you need to do are given in the Fuses and bulbs section of the Owner's Manual (assuming you have the same version as mine - p378) It can be done without removing anything else under the bonnet although, if you have large hands, try and enlist the help of someone with smaller hands. It a good idea to have the new bulbs out ready when you change and note the position of the lugs on the existing bulb as you remove it. This can make getting the new bulb into position a little easier.
