The age old -Parking sensors
jitvv
North Herts
Hi Guys,
New to the b6 section, Mrs has got a 2004 2.5 tdi Avant, been using the search function and found out how to remove the rear bumper and replaced a faulty Parking sensor, VCDS reported it faulty and was getting the long beep, since replacing it and cleared the error codes, when I select reverse I get the normal short beep, But it seems the sensors are not detecting as they should as they don't beep at all, if put the ignition on and select reverse (engine off) and walk around to the back of the car and cover a sensor it beeps as if your too close to something but not getting beeps telling you your getting close.
What could it be? Does something need to be coded?
Sorry for the long post, I hope I make sense.
Any help greatly appreciated. As Mrs needs them! :)
cheers
Just in case someone else has this issue, resolved mine by re coding Parking assi, and adaption of the buzzer volumes.
484
14
611
12
