Help with P0420 fault code
armstrong_21490
Ardrossan
I am getting the following fault code p0420 catalyst system below threshold
I was wondering if anyone has had any dealings with this code and what is causing it?
I have cleared the code but it comes back on after a while.
Ross
Ross
Ross-Tech Wiki post this info:
16786/P0402/001026 - Exhaust Gas Recirculation (EGR): Excessive Flow
Possible Symptoms
Malfunction Indicator Light (MIL) ON
Reduced Exhaust Gas Recirculation (EGR)
Reduced Power Output/Engine running rough
Increased Emissions
Possible Causes
Exhaust Gas Recirculation (EGR) Valve stuck open/leaking/faulty
Exhaust Gas Recirculation (EGR) System leaking/faulty
Wiring and/or Connector(s) from/to Exhaust Gas Recirculation (EGR) Valve faulty
Possible Solutions
Check/Clean Exhaust Gas Recirculation (EGR) System
Check/Replace Exhaust Gas Recirculation (EGR) Valve
Check Wiring and/or Connector(s) from/to Exhaust Gas Recirculation (EGR) Valve
Possible Symptoms
Increased Emissions
Possible Causes
Possible Solutions
Sorry bud I just realised i had put the wrong code in the title. I've changed it now.
3K
552
467
