My New Mod
antowens
Car Nut
Liverpool
In preparation for my honeycomb grill i am going to order i thought i would make my fog surrounds look the same
So abit of honeycomb grill and abit of hard work and here's the result hope you like it
20140819 135550
Reactions: ScottishA4B9, RS5 JON and P40ULW
Do you have a before photo? I think my car already has a honeycomb mesh around the fogs!
This is on a preface mate so the B8 before the one you have i think the new ones come with the honeycomb mesh moulded in mine never
Oh, I have some in my shed still...helps keeps leaves out of intakes and intercoolers as well
They do have plastic covers behind but i replaces it with some mesh and i think it looks really smart not massively noticeable but its the small things
Reactions: razza1
Looking good ant, try and get some more pics if you can :)
Reactions: antowens
I think your handiwork has sealed the deal with my thoughts about buying an RS4 front grille as these will match it nicely. Where did you get the mesh stuff from?
Reactions: antowens
Thanks mate and just of ebay just searched honeycomb mesh and found it it came from polland has a few different sizes i went for the 30mm x 10 mm and the sheet was 100cm x 40cm powder coated gloss black
Reactions: P40ULW
:icon thumright:As above, well done fella, it's on the ever growing list
Reactions: V6 Quatt and antowens
did mine a few month ago does make it look better
also did my B7's
Reactions: antowens
b7 rs4 is also different from the s-line b7.
Was easy to do in the b7, should be just as easy on the b8 I hope...
The only thing i found hard was because the surround has a few bends and arches to it so trying to get it right takes some time
didn't you use a hairdryer or heat gun for the curves ?
yeah the B8 is just as easy as the B7
Ye i done mine this morning while she was in work also the passenger one the back unhooks of it but the drivers one you have to Dremel it or cut it of some how don't know why Audi made one side removable and the other not but hey ho
fantastic job! this is on my to-do list on my A3. where did you get your mesh from?
Reactions: antowens
Thanks mate and just of ebay came from Poland took about 3 days i think just search black honeycomb mesh and it came up comes in different sizes
Ebay number is 110854214316
Reactions: Arkious
That is normally because access is required, used to be for towing point, forgotten if B8 has that there. I've done that a few times with previous cars, though I sprayed the wire mess.
Anything that keeps stones, filter tips and beech leaves out can't be bad! (oh and receipts)
The towing eye cover is on the bumper not behind there the only thing behind it i can see is a few pips hahaha
Great job ant, think you may have started something with this mod.
Thanks mate and ye seems like it doesn't it it looks smart when done as i said not massively noticeable but its the small things
Reactions: RS5 JON
10
785
