- Joined
- Oct 17, 2010
- Messages
- 362
- Reaction score
- 136
- Points
- 43
Hi Guys
I have a 57 S3 3 Door and I’m having issues where my one touch windows stop working and I’m more frequently having to go through the following cycle
I have done some research on here but no one seems to have the exact same problem. I found it could potentially be any of the following...
- Reset the one touch feature by opening the window and holding the switch for 6 seconds and then closing the window and holding for 6 seconds.
- After the one touch has been working for what can be a random period of time, I will close the window, it will get to the top but the window motor continues to click like it doesn’t know the window has got to the top. This clicking will continue until I cancel it on the window switch.
- The above will continue to happen until one time when I close the window, it will get to the top and then bounce back down roughly 10cm. At this point the one touch feature is still working. I then close the window again and it will bounce back down to 10cm again. At this point the one touch feature will no longer work and I go back to step 1.
- Convenience module.
- Window switch.
- Window motor.
- Software upgrade on electric window module?
- Window rubbers to tight.
- Upper door frames needs adjusting.
- Disconnect the battery for 30 min (I have done this but did not work).
