Airbag Light On Fault Code Help...
dale86
co durham
Here's the fault code has anyone come acctoss this before it's the one above your head on drivers side. I was wondering if it will be a wiring issue or replacing the unit if anyone could help it will be greatly appreciated my test is due Monday lol.
Check the connections under the seat, disconnect the battery, wait an hour, disconnect the plugs under the seat, clean the connections and reconnect, probably need the fault cleared again after that too.
I had an intermittent light on mine, after doing this it never come back on.
Oh and its really not my fault if the bag goes off ;)
More than likely a connector issue. Remove connector, spray some terminal connector spray in or clean with isoprol and reconnect. Might need light resetting via vagcom though
Had similar problem on my a4,left something on rear floor for a while then airbag light came on, checked with audi tec friend disconnect battery then carefully check plugs under seat and put small cable tie round plug sorted !!
Yip yellow connectors under seat will be culprit. As above remove clean with contact cleaner refit and reset with vcds.
829
873
5K
