hi all started having a few running issues with my car basicly when started from cold it misses and sounds like its running on 3 cylinders once you remove the load or get above 2000rpm its fine and will drive fun untill you stop at traffic lights and will cut out start up instantly read the car for fault codes and i have
p1602 power supply therminal 30 voltage to low
p1297 pressure drop between turbo and throttle valve
p1127 fuel trim bank 1 system to rich
