Hi all,.
Been having an intermittent fault with the rear passenger side lights.
I keep getting a warning light for the rear left brake light and/or rear left reverse bulb.
I removed the light and the bulbs are OK, but I noticed a couple of things.
1. The connector that plugs into the bulb unit has the little clip/ securing tab broken off. This is on the car side if the cable... I've seen you can buy the connector, but can you swap them somehow?? As the cable seems to be hard wired as it were.
2. When I pulled the connector apart there was a bit of moisture present... Is it common for the bulb holder seal to cause problems? I do get a bit of condensation showing in the reverse bulb area.
I've bodged the connector with tape to hold it,and that's not budging, but just noticed the bulb warning light still sometimes comes on!!!... Thinking it must be moisture related now.
Any ideas/ advice....??
