What spacers do I need?
Kido Skillz
Hello,
I've bought a set of Team Dynamics Pro Race on 17" x 7J with ET38 and I want to know what spacers should I get to get the wheels sit flush with the arches.
I was thinking for 20mm front 30mm rear, is that too much? I could go 25mm front and 30mm rear? Or less?
Thank you.
standard wheels are 7.5J ET32? So with your 7J ET38 you would need around 12-13mm spacer to match the standard poke
A lot of people go 10mm front and 15mm rear on the standard wheels, so you'd need 20-25mm front and 25-30mm rear - so either of your options, up to you. Pretty fat spacers either way...
I'd probably opt for hub-centric bolt on spacers, HnR do decent bolt on spacers, good quality and light - expensive though
Reactions: Kido Skillz
What do you think about 25mm F and 30mm R bolt on, are they safe?
The guy from the shop I used for years to get wheels and stuff, said they're ok bolt on as he fitted them to many cars like Porsche, BMW etc...
I've got 20mm bolt on HnR hubcentric on the rear of mine with 10s of thousands of miles on them and they've been fine
I've been running 25 front and 30mm rear on the rs4 for a few years, h and r bolt on hubcentric with no issues..
840
10
Yaz
821
908
