The iPhone seems to play 256k files better than the SD card for some reason.
Going off at a slight tangent, am I likely to notice much of a difference between 320kbps MP3s and 256kbps AACs
I presume the card & iphone use the same DAC in the car since the iPhone is through the lighting cable?
Cheers, I probably should have read that first.No.
Read through the link in post #4 above, iphone through green or yellow collar AMI is tortured.
It appears they're lossless, in my defence it was a late night..
Got to trawl through this lot..
In order of best to worst:
Audio CD (Red Book)
SD Card or Jukebox uncompressed (linear) audio
=SD Card 256 kbps AAC
=SD Card 320 kbps mp3
AMI Cable uncompressed audio
AMI Cable compressed audio
Streaming, WiFi & Bluetooth
Hahahaha I did wonder !!!
TBH, on AAC, anything over 256 - 320 kbps is just a waste of space, as I defy anyone to tell the difference, especially in a car, even with *** or B&O !!
Not to nit-pick but I'd put FLAC (or similar lossless but not necessarily uncompressed) at the top, as the CD ripping should be done with superior error correction on your PC vs. in-car CD player (and can also be cross-referenced against online CD databases for even greater accuracy).
My HDD iPod sounds better than the files on my SD card, I'll have to go and check what bitrate they've been exported at. HDD iPod is on its last legs, leaving it out in the cold is not helping the battery
I have alot of FLAC but can only really hear the difference on my home headphone setup. Didn't know the car would play it.
Thanks. I won't bother tryingIIRC FLAC only works on tech pack cars. It does on mine and mine's a tech pack car!
