NPM108
- Joined
- Aug 28, 2014
- Messages
- 10
- Reaction score
- 0
- Points
- 1
- Age
- 46
2.0 TFSI K03 - Stage 2+ with a VWR CAI and Miltek TBE
I've been doing some logging lately and have been noticing my MAF flow rates dropping over time. I apreciate that ambient temperatures play a role so I've been trying to log with consistent air temps.
A Stage 2+ K03 should run at around 270-280bhp so putting that into MAF g/s flow rates should be around 220g/s
I've seen around 205g/s in the past but lately haven't been getting past 188-190g/s under full load 3rd gear close to WOT. Filter in the VWR intake is clean. Coil packs are new as are he plugs, and DV is a new Rev.G that just went in.
No codes with VCDS and logs available. Unplugging the MAF at idle didn't change anything but I didn't try it on the road with the MAF unplugged.
Is it possible to have a dying MAF that is reading slow and slowly reporting less and less flow to the ECU. Both short term and long term fuel trims are -3.5% or there abouts so ECU is removing fuel presumably as airflow is less than expected from the ecu map.
My understanding was that the VWR intake was pretty good and should flow above 200g/s.
Any ideas?
Any ideas?
