Hi all,
I came across to a bit of a problem and after reading and searching for needed info I came to even more confusion.
Brief info:
Car was originally imported from US (a3 sportback '06). All parts are OEM, no after-market ones but someone has messed around with headlights (coding). Single xenon headlights were flickering which was due to wrong coding, which has been amended via VCDS.
Sitrep:
Headlight level toggle/switch (levels 0-I-II-III) does nothing.
In position 0 when the car starts xenons light up, instrument cluster stays unlit.
Auto position ("Auto" on the switch becomes orange-ish) xenons light up, instrument cluster lights up (I believe it adjusts to the daylight as well).
Once in third position, I believe that one is called parking lights (please correct me if I am wrong), xenons go off (please refer to Image 2 below), but the symbol on the switch itself doesn't light up in green (I don't know whether it should but in a lot of available topics it did).
Fourth position, xenons light up, front and rear fog lights are available to be switched on (symbols on the switch light up in different colors).
Instrument cluster illumination switch works perfectly.
I sense that there might be something mixed with the coding or the switch.
Is the headlight level toggle should be working with single xenons?
I would be grateful if someone could give me an idea of what is wrong from my write up or how the proper set-up should look/work like.
Cheers!
Light switch looks like this:
Third position on the light switch:
Images were taken from google search.
Brief info:
Sitrep:
Cheers!
