Car won't pull after 4k
vr6gordy
just been to see my dad about 40 miles away it's the longest I've been for along time in my car on the motorway the car has no power when you drop it in to 3rd to overtake .. I've just put cat back on the other week and been no where in it could it be it's still sorting it's self out still also when I had the car put back to standard after a crap map I had platinum plugs Still left in from the remap could it be a plug problem ?? Car pulls like a train in the low Rev range Audi a4 cab quattro 1.8t
Thinking back I replaced maf with one from euro car parts could it be the problem .. Coil packs are not all that old about 5 months tops
Best running some logs with VCDS if you have it.
You can usually work out the problem by looking at the air flow reading combined with fueling and requested boost.etc
Just done a quick scan with iPhone there are no codes logged just popped some new plugs in and it sounds a lot better not been for a drive yet
Limp mode or boost leaks? Would have surely shown something if it went into limp mode though.
Not limp mode it dose Rev past 4k but very slowly when driving . When car is still it Rev fine
I've never changed the pcv in the 4 years I've owned the car could that stop boost
I've got a new silicone turbo inlet pipe coming soon and I wanna replace all the pipes with silicone ones .. Been reading up and found the vag pipe could be sucking in under load
My money would be on the TIP collapsing
I hope it's that with the part I've go coming easy fix I hope
Just been out in the car and I had boost past 4k so tryied again and no boost after 4k
Got this coming Friday
Anyone no the clip sizes I need wanna get new ones
check the maf sensor by reading it in vcds
also did you change the n75 valve or standard re-circ valve
re-circ valve could be stuck open
N75 was replaced in the summer so it won't be that .. What is re-circ valve ??? You mean the dv found under the drivers side headlight if so replaced in the summer to .. If the Maf was faulty it would do the problem all the time car seems to fine when it's cold but soon as it's warm no power after 4k
What a dip stick all this time about 4 months ago I fitted a new n75 valve to my car because I've had a few things wrong with it after I had it remaped ( now back standard )when I fitted new n75 I've put it on the wrong way round DOH why didn't I think about that oh we'll never mind least it's fixxed now pulls like a train once more
Glad you have got it sorted and thanks for being honest about the fix. A lot of threads never have a conclusion because people don't report back on what the fix was.
Karl.
Had a lot on my mind over the last few months
23
14
NHN
947
