Single stage to dual stage airbag solution?...
grainqey
Rotherham
Hello,
I was thinking the other day about my mfsw swap and the airbag light being on.
Is it not possible to buy an airbag module and have it coded to the car that is from an '06 onwards (dual stage airbag) car? and hopefully then the airbag will deploy as it should with no wire butchering?
Alex
No one has found a solution to this, this is one retrofit I would stay well clear of.
Already done the retrofit - I figured i've already been in a car accident at speed and nutted the steering wheel so I've practiced? lol
Can anybody post a link to how to wire the airbag to get rid of the airbag light on an A3 8P? cant seem to find out how even on google
p.s I already know the airbag may not deploy, if I was bothered then I wouldn't have fitted it
How did you sort this mate???
Hello Muzzuz,
It was a case of buying another airbag loom and re-pinning it - I cant remember off the top of my head which pins go where to sort it without referring to the loom that I butchered.
Sorry I cant be more help, I could ask for the loom/try to get pictures of the loom to show what I did
Alex
Yes mate that would be a great help. I just don't like the old looking steering wheel on my car. The one I have bought will look a lot better, just don't want that airbag light on.. Cheers Kyle
Also did you need to buy a different slip ring for behind the steering wheel?? Thanks
Hi Kyle,
I didn't need to buy another slip ring but that could have been because of what slip ring I have as standard or it could just have been the bodgery of it all as there's no guarantee the airbag will deploy with this mod - I looked at trying to swap the airbag ecu but no idea if it would have just been an expensive paperweight so didn't bother trying to do it that way.
Alex
Right I got you mate.. Am I right that its just a case of the wiring inside of the steering wheel then? Thanks for the replys :)
Yeah basically, only butcher the actual loom as that's replaceable (ideally a spare as I did) - I might be able to get that loom I did back this weekend so I'll pm you about it if I do
That would be great mate... Thanks :)
