Audi33
- Joined
- Sep 26, 2014
- Messages
- 152
- Reaction score
- 13
- Points
- 18
- Age
- 31
Hello there, im having issues with fitting my hid kit. Wired everything up correctly as it should. When i was refitting them i would from time to time check if they work by putting the car in ignition, everything worked fine. No errors nothing as the kit ive got cancels out the errors.
When i switched on the car, the passenger one decided to switch off. Tried checking all the wiring everything was tight, the one on the otherside worked perfectly. So then i swapped over the ballasts too see of if they could be at fault. But still no hope that side never worked yet again.
So i took them off, checked all the bulbs and ballast with 12v power (from a power supply), strangley everythings working as it should!
What could be the issue? Any help would be appreciated
