BaileyA3
Hi guys, after a little bit of advice if possible. I have a 56 plate 2.0 tdi 170 (not sure which engine code) and today on the way home from work the oil pressure warning light came on beeping then went off again. I've just been out for a little drive to see if it came on again and the car started and drove fine and no oil pressure warning until I was just pulling up back home and it came on again. I did an oil and filter change last week and have just checked oil levels and all is fine. Had a quick look under the car to check for possible oil leaks and nothing that I could see. I've never had the pressure warning come on since I've had the car until now but when you push and hold the left stick on the dash it shows up in there which I'm guessing is logged faults and has been on there since before I had the car. Also (not sure if it's connected) but twice in the last few days the car has cut out immediately after starting up but started back up fine straight away (Never had this before either). Any advice would be very greatly appreciated as I'm worried about driving it now incase I do any damage. Also sorry for the very long post but wanted to get every bit of info down that might matter. Just hope it's not something big and expensive.
